Author Topic: Windshield w/ 2' blocks  (Read 1046 times)
Offline hank
« on: March 22, 2018, 10:14:11 pm »
I have installed the 2" blocks to raise the handlebars and now when my stock windshield is in the down position the handle bar (master brake & clutch cylinders) when turn all the way either right or left hit the windshield anyone ever run into this and what is a fix? Thanks for reading my post. Hank
Offline bowtie39
  • COG#: 10014
Re: Windshield w/ 2' blocks
« Reply #1 on: March 22, 2018, 10:38:13 pm »
Mine did the same.  Only thing I did was get in habit of holding the windshield button WHEN you turn engine off.  It will stop shield in that position.
Offline gsun
  • CDA #560
  • COG#: 9127
« Reply #2 on: March 23, 2018, 02:12:15 am »
Get a different windshield. You'll thank me for that suggestion on your first ride! ;D
Offline RoadKillHeaven
  • How hard can it be? 。◕‿◕。
« Reply #3 on: March 23, 2018, 03:25:04 am »
Advance Sport Touring sells 2 inch pullback raisers. No interference with windscreen using those.
Cheers...
Offline bowtie39
  • COG#: 10014
« Reply #4 on: March 23, 2018, 03:49:48 am »
Cheers...
Well that's the set I am using and it interfered with stocker.  Switched to CB and not hitting.
« Reply #5 on: March 23, 2018, 03:52:20 am »
I have theirs 2 inch pull (not 2 inch raisers) back and clearance is OK. Things are strange, indeed!
Offline Roger B
« Reply #6 on: March 23, 2018, 01:14:43 pm »
I have these also and no problem with windshield clearance.
Could you slightly bend or turn the brake fluid bracket for clearance...I don't remember how it is made and I'm not near my bike for reference.
Offline BiggusDekkus
  • COG#: 11944
« Reply #7 on: March 24, 2018, 12:22:01 am »
I have 2" risers from Helibars.  The stock windscreen when fully down will barely touch the clutch reservoirs when the handlebars are turned to the extreme right or extreme left position.  This does not cause any problem.  I recently installed a Puig touring windscreen and it does not touch the reservoirs.
2016 Gray C14
Jet Ski Ultra 300X & ST-15F
Lake Stevens, WA
