Author Topic: Winter storage  (Read 7151 times)
Offline Jigo
Re: Winter storage
« Reply #25 on: October 25, 2012, 01:13:53 pm »
I never opened the battery compartment yet..... how easy or how hard is to add a pigtail?
2006 Ninja 250R - Sold
2006 Honda CB900F - Traded
2008 Concours 14 - Current
Offline Dalroo
  • COG#: 9961
Re: Winter storage
« Reply #26 on: October 25, 2012, 02:41:00 pm »
Hi Bruce.
Keep in mind this advice is based on the few years I worked as a part time mechanic at a motorcycle shop and that was quite a few years ago.
At that time the direction received from the manufacturers was it is best to not start it during its hibernation unless it is going to get ridden.  The reasoning is unless you can bring the bike up to full operating temperatures (highway speeds for 8-10 miles) you cannot burn off the moisture brought into the engine and exhaust systems.  That moisture can be damaging to the inside of the engine and exhaust.  Part of our winterization process (in addition to the fuel treatment, pulling batteries, draining carb bowls, getting tires off pavement, etc) was to pull the plugs and spray a small amount of fogging oil in each cylinder.  Then let it sleep until the customer wanted it in the the spring.  These days....I do not perform the fogging step on my own machines but I still follow the rest.
So from my perspective....unless you can actually take the bike out for a ride and get it up to full operating temps....it is better to let it sleep.
+1 - I was told by a mechanic back in the early 90s that unless a motorcycle is ridden long enough to come up to full operating temperature, it is better to not start at all. As Soda said, condensation will form and does not have time to "burn" off unless it is ridden for some distance.
(Now) 2010 C14, 1981 KZ440LTD, 2014 XC610 (Then) 2000 FLHTCUI, 1998 KZ1000P, 1998 FXDWG, 1996 XL1200, 1993 Intruder 1400, 1989 YZ-250WR, 1984 YZ-250
Ancient Arabic Order of Nobles of the Mystic Shrine - Moslah Shrine Temple, Fort Worth, Texas - 2B1 ASK1
Offline Bruiser
  • Bruiser
Re: Winter storage
« Reply #27 on: October 25, 2012, 07:59:13 pm »
Thanks guys, I appreciate the advice.  I have heard mixed reviews over the years...start it once in awhile, or do not touch. Having just acquired a new C14 in July, I want to make sure I'm doing things the correct way.  I'm still riding it a few days a week, but here in Oregon, it's not too far away, that I'll be putting it to sleep.  Skiing is right around the corner!
Bruiser
2012 Kawasaki C14
93 Kawasaki C10
1982 Honda CX500 Turbo
1980 Kawasaki KZ1000ST
1978 Honda CB750F
1976 Kawasaki KZ400
1976 Honda 750K
1973 Honda CB500K
1973 Honda SL175
1972 Honda SL125
Offline Jigo
Re: Winter storage
« Reply #28 on: November 12, 2012, 01:29:04 am »
Installed a pigtail earlier. Getting her ready for winter storage.
Offline PaleRider
Re: Winter storage
« Reply #29 on: November 12, 2012, 07:14:42 pm »
I Like SeaFoam, I also plug my battery tender into my heated jacket connector in front of the seat. I also use center stand and 2x4 under front wheel. But I ride mine on and off all winter.
I run a 1/2 can seafoam every 4 tanks or so because of the ethanol.
cold ok.  rain not so much
Have Owned 2004 Honda VFR, 2004 Honda ST1300, 2000 Triumph Sprint ST.
Now 2012 ZG1400 in Pearl Arabian Red
Offline JimO
  • COG#: 10132
Re: Winter storage and Battery Tenders
« Reply #30 on: December 05, 2012, 02:37:43 am »
On my previous bike, a BMW, I could just plug the battery tender (with the correct adaptor) into one of the  accessory outlets and keep the battery on the tender that way. The C14 has an accessory outlet on the dash - anyone know if I can plug the tender into that?
Artaxerxes had served with great reputation in the armies of Artaban, the last king of the Parthians, and it appears he was driven into exile and rebellion by royal ingratitude, the customary reward for superior merit.
- Gibbon, The History of the Decline and Fall of the Roman Empire
Offline Dalroo
  • COG#: 9961
« Reply #31 on: December 05, 2012, 02:05:36 pm »
I do not think so - I may have the numbers a bit wrong, but the dash cigarette plug is 5 amps (?) and the tender needs more. I installed a powerlet plug on the right,  flat panel and it came with a 15 amp fuse which is enough to run the tender, and probably any accessory you choose.
Offline jonathan
« Reply #32 on: December 05, 2012, 02:19:18 pm »
You can't because on the C14 the OEM accessory outlet is only live/connected when the ignition switch is on.
Calgary, Alberta
Offline Udoggie
  • COG#: 10480
« Reply #33 on: December 05, 2012, 02:19:49 pm »
It is switched (i.e. disconnected from power when the C14 is turned off), so it wouldn't work for a tender.
Jeff
Offline EnsoniqDude
  • Running Down a Dream
Re: Winter storage
« Reply #34 on: December 05, 2012, 03:48:57 pm »
I hate meesus to pieces!
I've gone nuclear since I got back home.  Mechanical traps, glue traps and poison bait.  We're talking Linebacker III - kill all mice dead in a gross and vulgar manner.  They've destroyed and old classic car of mine and have attacked multiple bikes in my garage.  DEATH BE TO RODENTS!
2010 C14 - "Neptune Blue" - All praise be unto the blessed color!
2007 Ural Tourist
1997 ZX-11
1984 Nighthawk S
1976 CB750
1965 Dream
"Chicks dig me because I rarely wear underwear and when I do, its usually something strange and unusual."
Offline Tundra Tom
  • XLR8
  • COG#: 8925
Re: Winter storage
« Reply #35 on: December 05, 2012, 04:07:10 pm »
1974 Kawasaki H-1 500
1975 Norton 850 Commando
2013 BMW GS 650 Sertao
Offline 6thwisconsin
Re: Winter storage
« Reply #36 on: December 05, 2012, 05:53:39 pm »
Here's a couple links for non-ethanol gas stations:
http://pure-gas.org/
http://www.fuel-testers.com/state_guide_ethanol_laws.html
That pure-gas.org I have found to be pretty accurate.
In the milwaukee area, I have to drive 25 miles or so to get non ethanol gas.
Did that last Saturday during a 125 mile jaunt that will probably be my last ride of the season.
Time for the Seafoam & battery tender.
2009 Concours 14ABS (sold)
1974 cb550k0 custom build
1975 cb750f0 custom build
1974 cb550k0 stockish restomod
Offline JimO
  • COG#: 10132
Re: Winter storage
« Reply #37 on: December 05, 2012, 07:00:02 pm »
Thanks for the responses. Soon time then to take the covers off and attach the battery tender leads.....
Offline Necron99
  • rise again....
  • COG#: 9384
Re: Winter storage
« Reply #38 on: December 06, 2012, 03:35:03 pm »
Having lived the first 30 years of my life in North Dakota, I sure feel for you folks who have to let 'er sleep for the winter.  My ride to work this morning in Texas was about 60 degrees.  We seldom get below 20, and with Gerbings, that's just fine.
Offline JimO
  • COG#: 10132
Re: Winter storage
« Reply #39 on: December 06, 2012, 07:12:00 pm »
Thanks for the photo and please excuse my ignorance but it is possible to just connect the positive lead from the battery tender's pigtail  to the positive terminal of the battery and then the negative lead from the tender's pigtail to ground? That appears to be what you did here. Should I then disconnect the ground wire from the battery when the tender is plugged in? As you can tell, my knowledge of electricity is limited - I know it lurks in the walls of my house but that's about all.
Offline FireIdiot
  • COG#: 10033
Re: Winter storage
« Reply #40 on: December 07, 2012, 03:23:58 am »
You are supposed to put these up for the winter?!?! I ride unless it's snowing.
I installed a battery tender plug. I don't know where people normally put it, but I brought mine up the right side and tuck it between the tank and the faring in the groove. I also got the other side of the pigtail and wired it to a power outlet and level in in my tank bag. That way I can charge my phone or gps, even if the bike isn't running.
2010 C14 ABS
Member, Red Knights IL Chapter 21
CDA #0431
Offline jonathan
Re: Winter storage
« Reply #41 on: December 07, 2012, 03:09:09 pm »
You can wire the negative to either the battry post or to the frame. Both work. If you then disconnect the battry when you have the tender plugged in, the juice will not be able to get the the battery.
In short: Positive to battery positive post, negative to battery or frame ground, plug in to charge. Done.
Calgary, Alberta
Offline JimO
  • COG#: 10132
Re: Winter storage
« Reply #42 on: December 07, 2012, 04:48:03 pm »
Thanks. Very useful.  Also I thought I didn't have a mouse problem - hadn't seen one in the garage for 15 years. Put out some traps and poison out just to be on the safe side and when I checked my trap line had two of the little buggers.
Offline deb
  • deb
Re: Winter storage
« Reply #43 on: December 15, 2012, 09:56:20 pm »
Techron is a fuel cleaner additive, not a stabilizer. When you add Techron to the tank, you should ride it till it is empty to clean out the fuel injectors and valves, and then change the oil afterwards, because Techron tends to thin out the oil.
When you park the bike for the winter, you should put Stabil in the gas tank.
After reviewing this link, it seems that some guys fill the tank, park the bike and then add Stabil... while others add Stabil to empty tank, then ride to get tank filled, and then park the bike.  My question is whether it is ok to add Stabil to full tank after parking the bike for the winter.  Appreciate your response. :-[
deb
2011 C14
2003 C1000
Offline FireIdiot
  • COG#: 10033
Re: Winter storage
« Reply #44 on: December 15, 2012, 10:04:16 pm »
Not speaking for anyone else, but I think the reason is to get the fuel + stabilizer into the fuel system, not just the tank. After you add it, maybe pull it out and start it and let it run for a while to get the stabilizer into the fuel delivery system. Stabilizer will (or should) ensure you have fresh fuel when you bring it out of hibernation. Filling the tank (should) prevent moisture build up in the tank. Personally mine won't get parked long enough to need fuel stabilizer.
« Last Edit: December 15, 2012, 10:07:10 pm by FireIdiot »
2010 C14 ABS
CDA #0431
Offline 1965soda
  • COG#: 10056
Re: Winter storage
« Reply #45 on: December 16, 2012, 02:02:01 am »
You are exactly correct FI....there is a need to not only treat the fuel in the tank but get that treated fuel through the lines and injectors before shutting it down for the season.  Also agree....the full tank means less air space which means less chance of condensation and moisture inside the tank when there is changes in the temperature.  For those of us in the northland who cannot ride for a few months at a time...those are critical for a successfull awakening in the spring. :-)
Currently in garage: 2011 C14, 2007 FZ1, 2001 M900 S4, 1983 900 Seca, 2003 ZRX1200, 1982 650 Seca, 8? Husq 430
Rides of the past: 2002 ZRX1200, 1986 900 Ninja, 1999 Ducati 900ss, 2002 R6, 2005 FJR, 1998 C10, 1998 VTR1000, 1989 1100 Katana, 1983 CB1100F, 1985 900 Ninja, 1983 900 Seca, 1982 Seca turbo, 1982 CX500 turbo, 1982 750 Seca, 1983 550 Vision, 1974 CB400F, mid 70's Rupp :-)
