Author Topic: Wolo horn relay  (Read 749 times)
Offline Bruiser
  • Bruiser
Wolo horn relay
« on: May 05, 2013, 04:44:24 am »
Ok, you're going to love this one.  I installed a Wolo air horn a few months ago.  I did not use the relay...why?  Cuz it was an easier install w/o it, and it worked fine.  Anyway, I have been reading from others, that the horn w/o the relay could cause the switch to burn out.  So, yesterday I decided to install the relay.  The schematic I had, listed #87 on the relay as an option...either connect it to the pos on the horn, or leave it off.  Everything worked great leaving it unconnected, but thought I would try option "B", and connect it.  Several minutes later, I noticed the bike was "turned on", although the key was in the off position!  I turned the key to on, started the bike, and then could not turn it off.  The key would not turn.  Since I still had the battery exposed, I disconnected the negative, and the bike could then be turned off.  Hmmm.  I then disconnected the #87 to the horn positive, and everything works well.  Any electrical geniuses care to tell me what that was about?
Bruiser
2012 Kawasaki C14
93 Kawasaki C10
1982 Honda CX500 Turbo
1980 Kawasaki KZ1000ST
1978 Honda CB750F
1976 Kawasaki KZ400
1976 Honda 750K
1973 Honda CB500K
1973 Honda SL175
1972 Honda SL125
Offline EnsoniqDude
  • Running Down a Dream
Re: Wolo horn relay
« Reply #1 on: May 05, 2013, 06:00:55 am »
FM.
2010 C14 - "Neptune Blue" - All praise be unto the blessed color!
2007 Ural Tourist
1997 ZX-11
1984 Nighthawk S
1976 CB750
1965 Dream
"Chicks dig me because I rarely wear underwear and when I do, its usually something strange and unusual."
Offline RideBellChain
  • I ride because I can...
  • Nothing like a good sweeper on an empty road...
    • RideBellChain.com Send a bell, receive a free bell!
  • COG#: 10039
Re: Wolo horn relay
« Reply #2 on: May 05, 2013, 06:40:00 pm »
I've noticed a few "oddities" in regards to ground and lights on our bike.  Can't explain it, but make sure you use a dedicated ground wire.  That may help.
He's an article I wrote when I installed my Stebel on my Royal Star Venture - the Wolo is a "clone" - basically the same thing.  Hope that helps.
http://ridebellchain.com/ReadBlog.aspx?BlogId=16
Ride Safe!
Mark
http://www.RideBellChain.com
Road Captain SCRC 456 - West Palm Beach, FL
ROK ROK100028857
