Author Topic: YouTube  (Read 3230 times)
Offline Desert rdr
  • COG#: 9556
YouTube
« on: October 13, 2012, 03:26:25 am »
If you want to see a set ok saddle bags popping off check out you tube. Type in (Kawasaki concours bags fail. Breckinridge.)
Offline Gypsy JR
  • American Gypsy
  • Living the Gypsy Life
  • COG#: 9279
Re: YouTube
« Reply #1 on: October 13, 2012, 04:08:31 am »
Which is why we pin etc. them.
Having said that, I can find you a youtube showing pigs flying too.  :rotflmao: :truce:
Re: YouTube
« Reply #2 on: October 13, 2012, 09:17:18 am »
You mean this? If this is the one, it is just part of a much longer video that one of the guys did documenting a trip. This was just one of the highlights. But like last time I ask: Why does he just keep riding away?    ???
KAWASAKI SAFETY ISSUE. Concours 14 Luggage Fail.
Offline Necron99
  • rise again....
  • COG#: 9384
Re: YouTube
« Reply #3 on: October 13, 2012, 10:49:40 am »
Because he needs to find a safe place to turn around?
Offline Gypsy JR
  • American Gypsy
  • COG#: 9279
Re: YouTube
« Reply #4 on: October 13, 2012, 10:50:54 am »
Because it was staged? I dunno. Has anyone here seen someone else's C14 bag pop off? I haven't.
Offline Mad River Marc
  • COG#: 8442
Re: YouTube
« Reply #5 on: October 13, 2012, 02:37:17 pm »
Haven't "seen" it but in Rhode Island this past May we had a 14 have it's bag "Spontaneously eject"
Re: YouTube
« Reply #6 on: October 13, 2012, 09:17:43 pm »
+1   The couple riding were very surprised when they returned after the short ride. But it made it easier to go back looking for it.
Offline Bruiser
  • Bruiser
Re: YouTube
« Reply #7 on: October 14, 2012, 08:46:29 pm »
I haven't personally seen it happen.  In  July, I hit a pretty significant bump, that should have knocked off something, but did not.  However, I did pin mine, just in case.
Bruiser
2012 Kawasaki C14
93 Kawasaki C10
1982 Honda CX500 Turbo
1980 Kawasaki KZ1000ST
1978 Honda CB750F
1976 Kawasaki KZ400
1976 Honda 750K
1973 Honda CB500K
1973 Honda SL175
1972 Honda SL125
Offline Johnny
  • Conniecycle
  • COG#: 9773
Re: YouTube
« Reply #8 on: October 17, 2012, 05:43:41 pm »
Can you please explain what you did to pin your saddle bags? Has there ever been any sort of recall for this happening?
Offline Bruiser
  • Bruiser
Re: YouTube
« Reply #9 on: October 18, 2012, 03:36:11 am »
The front 'fork' of the saddlebag straddles the mount that the rear footpegs mount to, as I'm sure you know.  I found some 2 1/2 inch long, 3/8 inch hitch pins, that have the little ball bearing in the side of the tip, and a pull ring attached to the other end.  Found them in a fastener shop here in Eugene, Oregon.  Home Depot did not have em, but they do have pins using cotter pins, that could be used.  I then drilled a 3/8 inch hole while the bags were attached.  The first time I put the pins in, it was pretty tight, but you don't want them rattling around, or falling out.  Took about 10 minutes to do, and it is extra insurance against losing those puppies.
Bruiser
2012 Kawasaki C14
93 Kawasaki C10
1978 Honda CB750F
1976 Kawasaki KZ400
1976 Honda 750K
1973 Honda CB500K
1973 Honda SL175
1972 Honda SL125
Offline Bourne2Ride
  • COG#: 10541
Re: YouTube
« Reply #10 on: October 18, 2012, 07:12:49 pm »
I had a bag pop off, but it wasn't secured properly after I hit it with a concrete gas pump protector. So I guess I crashed mine off the bike, I've since replaced it, and knock on wood, I've been good.
CDA# 0425
