Author Topic: ZG 1400 Panel Access Tank Cover  (Read 1446 times)
Offline chinese
« on: December 02, 2017, 12:40:30 am »
Hi forumers
does anyone know where can purchase Panel Access Tank Cover ( with storage ) online .
Simon
Offline gpd323
Re: ZG 1400 Panel Access Tank Cover
« Reply #1 on: December 02, 2017, 07:54:37 pm »
I use Partszilla
Offline Tjnoma99
  • COG#: 12686
« Reply #2 on: December 04, 2017, 02:24:07 am »
Whats all needed to add the compartment?? I have a 13 and would really like to add that little space
« Reply #3 on: December 04, 2017, 03:13:51 pm »
Putting the Gen 1 tank "glove box" on a Gen 2 will unfortunately is not a plug and play type of installation. Under the black cover on the Gen 2's the mounting brackets are different so the gen 1 glove box won't fit. Which is unfortunate. It seems to me there is also something under the blank plate on the gen 2 which could need attention once in awhile. I can see where a Gen 1 tank box would be quite handy.
This was discussed some time back and a search might come up with something. As I recall a member was successful on installing one on his Gen 2 but was a royal pain in the ... neck.
Offline Rico
  • COG#: 12496
« Reply #5 on: December 04, 2017, 07:23:35 pm »
I know someone did this mod to mine.  I have a 2010 with a tank box.   It looked like all they had to do was move the relays to inside the left faring and then add a spacer under the front mounting bolt that is maybe an inch thick.   I am not sure what they did for the mounting bracket further back since I have never seen the non modded way.
Offline Tjnoma99
  • COG#: 12686
« Reply #6 on: December 05, 2017, 01:30:21 am »
I think its an awesome idea. I wonder why Kawasaki thought it was a good idea to stop putting that compartment on.
Online turbojoe78_MA
  • COG#: 8645
« Reply #7 on: December 06, 2017, 03:01:10 pm »
I installed one on my 2014.  I got the plastics used and had to buy the bracket for the rear two screws.
You have to relocate the relays off the stock bracket, I just moved them all off to the left side and zip tied them.
I didn't raise the front but instead used a dremel to remove some of the plastic from the bottom front left where the brake line was contacting the base.
I also bent the rear mounting bracket down 1/16" to 1/8" at the ends so the base would fit closer to the tank, and bent the brake line down slightly where it contacted the front of the base so I wouldn't have to cut away as much plastic opening up to the inside of the compartment.
I have never looked at how well a 08 or 09 fits but I'm going to guess that the job I did fits very close.
Offline Tjnoma99
  • COG#: 12686
« Reply #8 on: December 06, 2017, 04:31:36 pm »
Turbo- do you have any pics of the compartment on your tank? From the side?
Offline Just Cliff
  • COG#: 9547
« Reply #9 on: December 07, 2017, 01:25:55 pm »
Keep in mind that if you have or plan to use a lock ring tank bag it will not work with the early model storage compartment. I removed mine & made a flat cover for this very reason.
Cliff   :beerchug:
Cliff
2014 1000 V Strom
  • COG#: 8645
« Reply #10 on: December 08, 2017, 12:02:05 am »
I'll see if I can get a picture and post it tomorrow.
Offline Tjnoma99
  • COG#: 12686
« Reply #11 on: December 08, 2017, 12:05:14 am »
Turbo- thank you.
Cliff- i dont use tank bags very often. I have a magnetic one if i do need to use it.
