Author Topic: zx14 rotors  (Read 5745 times)
Offline br
  • If you wana get fast, ride lots
zx14 rotors
« on: March 30, 2014, 01:49:24 pm »
Just had the rotors on my 2011 c14 replaced for the second time. The only difference this time is the Kawasaki rep recommended the zx14 rotors and new pads. They must know there is some kind of a issue. All was covered under warranty.... br
Offline guycnicholas
Re: zx14 rotors
« Reply #1 on: December 29, 2016, 07:19:56 pm »
 I know this is an old topic and you probably won't see my response, but hey, I gotta try.  Can you tell me why you had them replaced?  What was the problem?
Offline gPink
  • MMVIII C XIV
Re: zx14 rotors
« Reply #2 on: December 29, 2016, 07:45:43 pm »
warpage
Offline hlh1
  • COG#: 548
Re: zx14 rotors
« Reply #3 on: December 30, 2016, 06:14:45 pm »
Are the ZX14 rotors better than the C14 rotors?  How?
Offline Grendel
Re: zx14 rotors
« Reply #4 on: December 31, 2016, 06:35:38 am »
Are the ZX14 rotors a direct swap?  I have seen quite a few rotors for the ZX14, but not much listed for the C14.  If they are the same then I can look up ZX14 rotors and install those.
Ryan
Offline Zarticus
  • COG#: 10785
Re: zx14 rotors
« Reply #5 on: December 31, 2016, 12:32:28 pm »
Ryan
The rotors are a direct swap, So is the front wheel. I have the front wheel, Rotors & all hardware from a 2012 ZX14 on my 2012 Connie  :beerchug:
1986 Honda V65 Magna, Black
1984 Honda V65 Magna, Black
1983 Honda V45 Sabre, Red
Offline seagiant1
Re: zx14 rotors
« Reply #6 on: December 31, 2016, 01:38:11 pm »
Ryan
Hi,
        So.....What is the difference?
There has to be something if the ZX-14 rotors are considered,"better"????
Just sayin, curious? ;D
Thanks for the info! :great:
Saw this!    http://www.zxforums.com/forums/zx-14-forum/55992-warped-rotors-issue-14-a.html
« Last Edit: December 31, 2016, 01:46:42 pm by seagiant1 »
Offline gpd323
Re: zx14 rotors
« Reply #7 on: December 31, 2016, 03:13:12 pm »
Ryan
YUP! I too have ZX14 wheels and OEM rotors that fit my C14, however I was not going to do a warrantee over and over due to warped rotors (my ZX14 rotors warped in 3000 miles) so I went with the Brake-Tech full floating axis rotors on both ZX14 and C14. No more issues. And on the C14 I went with the 330mm big brake kit.
C14 BT Axis full floating
Offline LinuxGuyGary
  • Black & Green... The fastest Color
  • COG#: 12089
Re: zx14 rotors
« Reply #8 on: December 31, 2016, 03:37:56 pm »
Do you have a link to these or part numbers?
Looking over their site I'm not able to find them.
-Gary
2011 C14 Black-n-Green
Eastern Utah
Re: zx14 rotors
« Reply #9 on: December 31, 2016, 05:10:03 pm »
Look good.
How long have you been running them?
Offline hlh1
  • COG#: 548
Re: zx14 rotors
« Reply #10 on: December 31, 2016, 07:58:06 pm »
I'm not hearing any benefits of the ZX14 rotors...  Guess they're bad like the C14.
Offline gpd323
Re: zx14 rotors
« Reply #11 on: December 31, 2016, 09:33:24 pm »
Here are the part # lists, I purchased the 330mm kit for the C14. I have the 320mm kit on the ZX14. 74K miles on the Brake-Techs on the ZX14, no warping. 30K miles on the Brake -Techs on the C14, no warping. I run stock brake pads because after going through several other brands the OEM pads work the best.
They rotors wear very well, are true full floating. Be aware though that they do rattle a bit at slow speeds when hitting a bump. Otherwise silent running.
http://braketech.com/images/docs/bt-kawapps.9-15.pdf
http://braketech.com/axis-iron-rotors-2/
I know the link say IRON rotors, but it should show the SS ones.
On the C14 if you look closely you will see 10mm spacers on the calipers, that are aluminum. The spacers locate the caliper 10mm further outboard for the larger rotors.
Offline hlh1
  • COG#: 548
Re: zx14 rotors
« Reply #12 on: December 31, 2016, 10:16:46 pm »
Thanks Greg, good info.
Offline gpd323
Re: zx14 rotors
« Reply #13 on: December 31, 2016, 10:40:41 pm »
its been determined the OEM brake pad material is also to blame, pads from a 2012+ ZX14 is the best compound. Or 2012+ C14. I don't know why, or what the change in pads compounds are or were. This is just investigating on the web, and of course everything on the web is true.  ::)
Offline Grendel
Re: zx14 rotors
« Reply #14 on: January 01, 2017, 09:57:16 am »
So, I have a 2014 C14 with stock brakes.  Should I be ok with what it came with, or is the ZX14 rotors and pads any kind of upgrade for my C14?
Ryan
Offline hlh1
  • COG#: 548
Re: zx14 rotors
« Reply #15 on: January 01, 2017, 12:37:38 pm »
Do I have to specifically ask for the 2012+ pads from the Kawasaki dealer or is this what they now stock?  I have an 09 C14.
Offline gpd323
Re: zx14 rotors
« Reply #16 on: January 01, 2017, 02:33:18 pm »
Ryan
Not an upgrade, the C14 has the same rotors as the ZX14.
Offline gpd323
Re: zx14 rotors
« Reply #17 on: January 01, 2017, 02:35:42 pm »
I buy my pads from Partszilla to purchase OEM items. I don't know the answer to that, but I doubt an older compound pad from way back would be still on a shelf for purchase?
Offline cuda
  • Ignorance Is Bliss.
  • COG#: 11405
Re: zx14 rotors
« Reply #18 on: January 01, 2017, 04:09:49 pm »
I do like the LOOKS of those big rotors , but I still have the original stock set up , with no problems
I don't use the brakes much , I use the engine down shifting to slow down ...
Oh yeah and my big feet like Fred Flintstone  , I like to see sparks fly  WILMA!
https://youtu.be/skeg3Y6sptg
« Last Edit: January 01, 2017, 09:22:29 pm by cuda »
Offline gpd323
Re: zx14 rotors
« Reply #19 on: January 01, 2017, 04:15:12 pm »
I don't use the brakes that often either, I ride the pace. But I knew at some point my rotors would warp on the C14 so I proactively bought the Brake-Techs. I still have the OEM rotors sitting in my closet of shame.  :beerchug:
Offline Grendel
Re: zx14 rotors
« Reply #20 on: January 02, 2017, 06:26:54 am »
I have seen quite a few people claim one of the first upgrades one should do to the C14 before power is brakes.  I'm looking into the steel braided lines, is that all that's needed?  What about the EBC rotors?
Offline hlh1
  • COG#: 548
Re: zx14 rotors
« Reply #21 on: January 02, 2017, 12:39:50 pm »
Except for warping under heavy use, the C14 brakes are amazing.  Also, I understand that the stock brake lines are steel(?).  If mine every warp I might go to the EBC rotors.
Offline AmphibSailor
  • Cibolo, TX Hooligan.
  • COG#: 12210
Re: zx14 rotors
« Reply #22 on: January 02, 2017, 03:42:08 pm »
From what I'm told, the one brake lines ARE braided steel...I heard someone cut one to verify.  When I put my Helibar Horizon ST's on I used Galfer braided s/s+6's vice the included extensions.  I didn't notice much difference... :motonoises:
Offline seagiant1
Re: zx14 rotors
« Reply #23 on: January 02, 2017, 04:27:46 pm »
Hi,
        I've never had any problem on my 2012. with brakes...
I think the OEM's are good to go!
What I did do, to make a difference, is change out the brake fluid, and bleed the brakes well.
My brakes were BETTER, then, than the way they came from the factory! :great:
Offline Grendel
Re: zx14 rotors
« Reply #24 on: January 03, 2017, 03:41:41 am »
Hi,
I believe that the factory ships the bikes dry, and the dealer has to do all that when they put it together.   That could explain the brakes if someone @ the dealership just kinda slapped it together.
Ryan
