Author Topic: NEW oils  (Read 769 times)
Offline RWJC
  • COG#: 9827
NEW oils
« on: November 05, 2011, 09:50:54 am »
I know energy conserving is bad for bikes. Now they seem to call it resource conserving. Royal Purple's new line @ aUTOZONE & OTHER FINE STORES ALL HAVE "RESOURCE CONSERVING" ON THEM WHICH i BELIEVE THAT MAKES THEM UNABLE TO BE USED IN OUR BIKES. iS THAT CORRECT??
~RWJC
COG #9827
"Dress for the crash, not for the ride."
02'VN800-SOLD 59,348mi 02'ZG1000-GONE 05'Nomad-SOLD   05'ZG1000-(12/1)5500mi(1/1)8220mi
Offline Outback Jon
  • COG#: 9506
Re: NEW oils
« Reply #1 on: November 05, 2011, 11:54:55 am »
"Resource Conserving" sounds more like it is reclaimed/recycled oil.  (I don't know, that's just what it sounds like to me.)
Offline Pat and Sher in MA
  • COG#: 7670
Re: NEW oils
« Reply #2 on: November 05, 2011, 01:26:31 pm »
I'm with Outback Jon, That sounds like it has reclaimed/recycled oil in it like the new Valvoline
NextGen oils you see advertised. It will be interesting to see what additives are put into them
and see if they are okay for motorcycle use.
Pat & Sher in Ma.  04 C10 Dark Angel,  87 Ninja 600RX
Offline wild man
  • COG#: 6174
Re: NEW oils
« Reply #3 on: November 05, 2011, 01:38:49 pm »
Speaking of NEW oils Rotella has a new 10W-30 semi synthetic for diesels, I think it comes in 10W-40 as well
Bill
USAF Ret, KC0IGL
AMA#333772, IBA#19247
2007 KLR 650, 1997 ATK 605
Offline Slybones
  • COG#: 6953
Re: NEW oils
« Reply #4 on: November 05, 2011, 04:03:14 pm »
Resource conserving is the new energy conserving. Its part of the API approval of the new SN rating that is updating/replacing the SM rating, approved in 2010 and being intruduced into the market in late 2010 and 2011.
Where energy conserving was only about increasing fuel ecenomy by adding the modifiers, resource conserving is about increasing fuel economy by adding the modifiers and also reducing catalytic converter failures by reducing the amount of ZDDP in the oil.
2003 Concours, 121K
2005 GL1800ABS, 52K
COG #6953, IBA 28004
Offline RWJC
  • COG#: 9827
Re: NEW oils
« Reply #5 on: November 05, 2011, 08:21:59 pm »
SOOOOO, then NOT safe in motorcycle use??
~RWJC
COG #9827
