Author Topic: '97 C1000 Motor coil in spark plug cavity of my middle cylinders  (Read 216 times)
Offline Jay
  • COG#: 12795
I just changed my spark plugs on my Connie.  I've owned her for about a year now.  The #2 plug hole has some oil accumulation on it and # 3 plug hole had a LOT of oil around it.  I don't appear to be burning oil and there's no oil drips off the engine.  I suspect it's a leaking valve gasket, but thought I'd ask the group.  It's hard to see much and I'd rather not start pulling valve covers, etc without feedback.  Thanks
Re: '97 C1000 Motor coil in spark plug cavity of my middle cylinders
« Reply #1 on: June 24, 2019, 12:37:46 pm »
  You may need gaskets for the sparkplug holes. I never reuse the old rubber gaskets. Look here for the gaskets.
https://www.murphskits.com/product_info.php?cPath=1_105&products_id=34&osCsid=aqHhkxMcUoQXQwrQu7pOd1
Offline DC Concours
  • 2001 Concours, ~25K miles
« Reply #2 on: June 24, 2019, 01:09:25 pm »
Yup. As mettler says. These should be changed every valve adjustment.
