Author Topic: Getting rid of "the buzz"  (Read 13088 times)
Re: Getting rid of "the buzz"
« Reply #75 on: October 25, 2014, 10:27:06 pm »
The point is to apply some tension on the cables and linkage parts.
Offline Scott
  • COG#: 11703
« Reply #76 on: October 27, 2014, 05:15:58 pm »
Thanks Turbojoe. Will do next time I open the plastics again. Riding season nearing the end in Norwell? I hope not! Still holding out in Wakefield!
Offline turbojoe78_MA
  • COG#: 8645
« Reply #77 on: October 28, 2014, 11:31:34 am »
I have been putting the bike away after thanksgiving the last few years, we'll see how the weather looks around that time.
Offline Scott
  • COG#: 11703
« Reply #78 on: October 28, 2014, 09:22:56 pm »
Not to rob this thread but does anyone know what size the upper engine mount bolts are?
  • COG#: 8645
« Reply #79 on: October 29, 2014, 01:18:11 pm »
Offline Larry_Buck_FL
    • Buck Sport Touring
  • COG#: 3451
« Reply #80 on: October 29, 2014, 02:58:29 pm »
Winter is coming for many of you and it would be a great time to shim the upper bolt(s). Just sayin.
Offline Jim
  • Jim
« Reply #81 on: October 29, 2014, 04:42:14 pm »
Jorge,
My experience is there is a significant difference between syncing at idle and 4K.  #1 and #4 are much higher on my homemade manometer.  In fact, #1 and #4 are just about to suck the ATF out of my tube at idle.  At 4K they are dead even.  I suspect this has something to do with the throttle linkage flexing because of spring tension.  Granted, at 4K under load my setup may not be close, either.
Offline JimBob
  • Woman...WHOAAAA MAN!
« Reply #82 on: October 31, 2014, 01:54:53 pm »
Jorge,
I'd be more inclined to think greater vacuum at idle is caused by better compression on #1 and #4...which could be balanced as simply as doing a valve adjustment!
(Of course, valve adjustment may not resolve it, but assuming the rings are good, you could see a LOT of vacuum difference from one cylinder to another based on valve adjustment, as demonstrated in Steve's latest video).
Offline Pbfoot
  • COG#: 10807
« Reply #83 on: October 31, 2014, 02:15:13 pm »
Foam grips .
Offline JimBob
« Reply #84 on: October 31, 2014, 05:54:50 pm »
Foam grips .
How do foam grips get rid of the buzz in the footpegs? Or am I putting them on wrong? :))
Offline Pbfoot
  • COG#: 10807
« Reply #85 on: November 01, 2014, 02:11:52 am »
I am not experiencing a buzz in the foot pegs. I guess you could try it if you are desperate. ;D
Offline Jorge
  • COG#: 9297
« Reply #86 on: November 02, 2014, 12:58:18 am »
Jim
Thanks, I've never  checked for the difference between idle and 4KRPM; I'll need to do that next time. I just it doesn't suck the ATF out of MY setup. I think that (using ATF) makes me as much a cheapskate as you  :great:
Jorge
