Author Topic: Carb cleaner  (Read 831 times)
Offline MrSkydriver
  • When all else fails, read the instructions!
  • Gregg Hackett
  • COG#: 10363
Carb cleaner
« on: August 10, 2012, 05:00:05 pm »
Anyone have a preference for carb cleaner?
Thanks,
Gregg
Gregg Hackett
'08 Concours C14 ABS
Boerne, TX
COG #10363
Growing old is mandatory...Growing up is optional
Offline SmokinRZ
  • COG#: 9430
Re: Carb cleaner
« Reply #1 on: August 10, 2012, 05:12:24 pm »
I use two different brands, a can of the cheap stuff (walmart) and a can of the expensive stuff (B12).  It might be my imagination but it seems to me like one will always clean stuff that the other one wont regardless of which one I use first.  None of them work as well as they did 20 years ago  :'(
Offline SteveJ.
  • COG#: 5603
Re: Carb cleaner
« Reply #2 on: August 10, 2012, 06:35:49 pm »
Tick Tock, baby (Ironbuttal)
Offline wlkn_mn
  • COG#: 10360
Re: Carb cleaner
« Reply #3 on: August 10, 2012, 07:14:39 pm »
B-12 Chemtool gets my vote. Just don't get it on yourself.
Offline cra-z1000
  • Keeping it upright..
  • COG#: 9790
Re: Carb cleaner
« Reply #4 on: August 10, 2012, 07:40:51 pm »
+1 on B12 just use it sparingly and don't let pour in cleaners sit in the carbs......run it through .
1987 C 10
80 Kawasaki KZ 1000 MK 2
74 Honda 750 four ss
73 Suzuki 550 triple
72 Honda 550 four
Offline wild man
  • COG#: 6174
Re: Carb cleaner
« Reply #5 on: August 10, 2012, 08:13:48 pm »
Continued use is the best way to keep the carb cleans, short of that any of the above cleaners does fine maybe once a year and no more.  I would also recommend doing an oil change afterwards, that's what the companies use to recommend back in the day not sure if it holds true today.  My carbs are in good shape so the only thing I use is Staybyl marine formula say every 5th tank or so to chase out water and alcohol additives.  Towards the end of riding season I'll use it every tank to ensure the fuel is treated for the bikes 3 month nap.
Bill
USAF Ret, KC0IGL
AMA#333772, IBA#19247
2007 KLR 650, 1997 ATK 605
