Author Topic: "Hoppy" at low RPMs  (Read 1172 times)
  • --2006 Concours--
"Hoppy" at low RPMs
« on: March 10, 2012, 10:27:20 pm »
So, the bike has been running great... I really can't complain... BUT
From a stop, and on a slow roll, Connie does not like a slow throttle roll
to ~3k RPM.  As I live in the speed bump capital of the world, being able to
keep the throttle 'in check' would make life easier on a slow roll.
Best way to explain the symptom, is the bike does not accelerate smoothly
when I roll the throttle back slowly, until about 2700 rpms, then it runs fine.
The carbs were cleaned by the stealership in December, and this issue has
surfaced shortly afterwards.  I'm done with the stealers...  I've been running
Sunoco 89 octane regularly.  I plan to get SISF to do the carbs...
Just wondered if something I can do till then to make the bike more agreeable
at low RPMs.
Re: "Hoppy" at low RPMs
« Reply #1 on: March 11, 2012, 01:20:17 am »
That's common to stock jetting. I'd elaborate, but I'm just coming in from our wrench session and I'm connie'd out right now. steve
Offline SteveJ.
  • COG#: 5603
« Reply #2 on: March 11, 2012, 02:20:57 am »
at low RPMs.
Usually on a stock, standard engine, 87 octane is fine. Also, Sunoco is not a Top Tier gasoline. You may wanna start using Shell, Chevron, Mobil, Texaco, or Exxon.
Linky:
http://www.toptiergas.com/retailers.html
Tick Tock, baby (Ironbuttal)
Offline 2linby
  • I rode today, did you?
  • COG#: 5539
« Reply #3 on: March 11, 2012, 02:42:59 am »
at low RPMs.
Wear a neck brace!  ;) Honestly no. Get a two minute mod from SISF smooth sailing from then on............. :)
« Reply #4 on: March 11, 2012, 03:34:04 am »
  Clean carbs and Steve's 2 minute mod will probably cure that. I know my bike runs a LOT better at low rpm after the 2MM.
Offline Jorge
  • COG#: 9297
« Reply #5 on: March 11, 2012, 03:44:53 am »
Mine does exactly the same (it's 100% stock in engine).
It seems to HATE running at part throttle around 2000 RM, but below 1500 it seems to not buck as much. We live in a quiet neighborhood and my wife reminds me of that sometimes (not so much any more). I usually get it up to 30 MPH or so, then shift up to get the RPM's around 1500, and it does not buck then.
Since it's a light load on the engine (level street) I can't imagine it will do any harm to it, and it is very quiet under those conditions.
Jorge
  • --2006 Concours--
« Reply #6 on: March 11, 2012, 12:00:33 pm »
Ok.  If it's nothing out of the norm for a 100% stock bike, I'm less
worried about it.  In a few weeks I'll be tearing out the carbs and
sending them off...  Been wanting to do it for a while now, but it
seems every time I have the $$$, other crap comes up.
I'll also take the longer ride to the Mobil station  :)
Nothing like a good reason to take a longer ride.   :motonoises:
Thanks for the input guys.
« Reply #7 on: March 11, 2012, 01:16:35 pm »
at low RPMs.
Short of doing it yourself, there is not anything else that needs to be done. You can try running some Techron or Seafoam through them but that may not help at all.
Sounds like plan!
