Author Topic: Buffeting gone!  (Read 1566 times)
Offline stevedap
  • COG#: 10998
Buffeting gone!
« on: June 08, 2013, 01:09:25 pm »
After researching the topic here and elsewhere I finally replaced my stock Connie wind shield with one I made. The stock one was both an eye sore and made riding at speeds over 50 mph way too uncomfortable. Total cost came to $26 plus about 5 hours labour.  I used 1/8" polycarbonate, a router to cut out the shape followed by a drum sander to smooth the edges. Very happy with the results.
« Last Edit: June 08, 2013, 06:11:37 pm by stevedap »
“Never underestimate the difficulty of changing false beliefs by facts.” --- Henry Rosovsky
"The task is... not so much to see what no one has yet seen, but to think what nobody has yet thought, about that which everybody sees." --- Erwin Schrödinger
____________________________________
Offline john_boy_cog
    • spas and more
Re: Buffeting gone!
« Reply #1 on: June 08, 2013, 02:53:10 pm »
Looking good
Offline DBLOCK
Re: Buffeting gone!
« Reply #2 on: June 08, 2013, 02:59:51 pm »
How did you determine how long to make the new one to eliminate the buffeting?
Offline stevedap
  • COG#: 10998
Re: Buffeting gone!
« Reply #3 on: June 08, 2013, 05:24:22 pm »
I made it so the top of the shield sits just below eye level when sitting normally on the bike.  However I think a major cause of the buffeting on the stock shield is the reverse lip at the top and the curved shape of the entire shield.
« Last Edit: June 08, 2013, 06:16:12 pm by stevedap »
Offline Bruiser
  • Bruiser
  • COG#: 10410
Re: Buffeting gone!
« Reply #4 on: June 08, 2013, 05:52:13 pm »
 I have a friend with a C10, makes own shields, and he also found the stock lip contributed to the buffetting
Bruiser
2012 Kawasaki C14
93 Kawasaki C10
1982 Honda CX500 Turbo
1980 Kawasaki KZ1000ST
1978 Honda CB750F
1976 Kawasaki KZ400
1976 Honda 750K
1973 Honda CB500K
1973 Honda SL175
1972 Honda SL125
Offline Mortech
  • COG#: 12208
Re: Buffeting gone!
« Reply #5 on: June 09, 2013, 03:07:04 am »
Nice job , I wish thicker sheets of it were available .
1999 Kawasaki Concours - Conrad
2006 Honda CBR600F4i - Restless
2009 Kawasaki Concours - Constanza
Offline stevedap
  • COG#: 10998
Re: Buffeting gone!
« Reply #6 on: June 09, 2013, 01:13:15 pm »
I used 3mm Makrolon (Bayer) which is actually a little under 1/8".  Maybe this brand of pc is stiffer than Lexan? Anything thicker and it would have been very difficult to bend the screen to attach the windscreen screws. Once attached it feels very stiff and solid - up to 80 mph so far.
Offline ron203
  • COG#: 9847
Re: Buffeting gone!
« Reply #7 on: June 09, 2013, 02:14:40 pm »
Nice job. Sort of like a Rifle shield. A Rifle shield is straight with no "flip" either and it doesn't buffet if it's high enough. I like the side tapers on yours.
2014 C-14
2008 Goldwing
Offline stevedap
  • COG#: 10998
Re: Buffeting gone!
« Reply #8 on: June 09, 2013, 03:11:04 pm »
Thanks... mine is 22" high from the base...works great.
Offline Sirius Scratch
  • zzzzzZZZZZZZ
  • She's gone.
  • COG#: 9105
Re: Buffeting gone!
« Reply #9 on: June 09, 2013, 03:35:22 pm »
Did you warm/heat your new custom shield in any fashion and form it prior to mounting, or did you mount the flat PC cold on the fairing one fastener at a time?
Sirius Scratch
1999 Hot Rod Concours. Now sold
2008 Burgman 650 Executive Temporary Solution
COG#9105
CDA0337
Offline stevedap
  • COG#: 10998
Re: Buffeting gone!
« Reply #10 on: June 09, 2013, 04:50:12 pm »
I mounted it cold one fastener at a time. You can fold pc 180 degrees back on itself and it won't crack. What's critical is the holes for the fasteners have to be perfectly aligned. I used a strip of card stock taped to the bottom of the oem shield as a template to get the shape and hole alignment.
Offline cal
Re: Buffeting gone!
« Reply #11 on: June 09, 2013, 09:41:52 pm »
That looks real good!
