Author Topic: [Noob Question] Fairing Pocket Door Spring  (Read 3283 times)
Offline Frankshay
  • COG#: 9944
« on: March 09, 2012, 02:09:26 pm »
I've pretty much finished my winter work list and am reassembling my '03.  The bike is pretty new to me so I want to get some miles on it before considering other work.  The problem is that I can't remember how the fairing pocket door spring is supposed to connect to the plastic piece that mounts the door itself.  (I mean the spring steel u-shaped piece that is there to either push the door open or pull it closed.)
I thought you had to reach through the small opening inside the pocket to "hook" the spring onto part of the plastic of the door mount but it doesn't seem right.  Can someone please walk me through it? Is the spring supposed to push the door open or ?  I know, I know, stupid question but usually I can figure these things out...   :17:
thanks,
Frank
Re: [Noob Question] Fairing Pocket Door Spring
« Reply #1 on: March 09, 2012, 05:19:01 pm »
Well I may be missing the point but no fairing pocket on a Concours that I have seen had a spring to open or close it.  I wonder if this is a modification?
Offline troidus
  • COG#: 8888
« Reply #2 on: March 09, 2012, 09:14:18 pm »
+1 on :017:
Offline MizzouMike
  • "I'm like a rain magnet"
  • COG#: 8862
« Reply #3 on: March 09, 2012, 09:33:06 pm »
Considering how many times I forget to latch the pockets on the C-10, I am sure if I had a spring my flaps would always be open (kind of like the toilet seat my wife keeps complaining about  :nananana:)
2014 BMW R1200GS
AMA, COG, IBA
Offline 2linby
  • I rode today, did you?
  • COG#: 5539
« Reply #4 on: March 09, 2012, 09:37:51 pm »
Spring?  Maybe you got the Deluxe model!~  :rotflmao: :rotflmao:
Offline ron203
  • COG#: 9847
« Reply #5 on: March 09, 2012, 11:25:46 pm »
Not on my 2000. Maybe you've got a "spare" part? Happens to me sometimes, but that doesn't usually end well..... :(
2014 C-14
2008 Goldwing
Offline Outback Jon
  • COG#: 9506
« Reply #6 on: March 10, 2012, 01:55:30 am »
As I own the penultimate 2006 C10, in the fastest available color, with all the factory options :017: available from Kawasaki, I can assure you that there was no spring on the fairing pocket lids ever available.
Although, if it was designed to keep the pocket open, I can see how it would be a nice addition.
Offline Frankshay
  • COG#: 9944
« Reply #7 on: March 10, 2012, 02:16:01 am »
Well, that might explain why I'm having trouble hooking the stupid thing up!   :))
Maybe the spring-thing is intended just to hold the edge of the fairing interior in place so you can get a couple of screws started.  Why else would they use spring steel there?
thanks
Offline CRocker
  • '02 C10 CDA # 416
« Reply #8 on: March 10, 2012, 05:41:17 am »
Can you show us a pic?
Offline Frankshay
  • COG#: 9944
« Reply #9 on: March 10, 2012, 08:35:27 pm »
I guess I should have done this sooner...
Offline 2linby
  • COG#: 5539
« Reply #10 on: March 10, 2012, 08:41:19 pm »
Ah!  The bafusalore spring!  :-\ It is there to keep proper tension between the plastimagifoil mantangle and the diafragmatical indicitor.  :D
Offline CRocker
  • '02 C10 CDA # 416
« Reply #11 on: March 10, 2012, 09:11:26 pm »
Well...that should simplify things!
Really...I have no idea...
  • --2006 Concours--
« Reply #12 on: March 10, 2012, 10:34:16 pm »
Ok... I have the Kawasaki Service Manual for this motorcycle, and I know for a FACT you mis-spelled "plastimagifoil".
Let's try to provide the correct info here.... OK??
On a less brighter note, I have come to the conclusion that I am missing this plastimagAfoil mantangle tensioner spring.
Offline Carlson
« Reply #13 on: March 11, 2012, 12:41:02 am »
I'm pretty sure this bafusalore spring has nothing to do with the door itself. It's there to hold the side panels to the around-the-instrument-cluster-plastic-thingy (on which that spring is installed)
2001 Concours  (sold)
« Reply #14 on: March 11, 2012, 03:50:53 am »
 Hell,I just looked at my bike and I have those springs also. For 18yrs I didn't even know I had those and I've it apart a WHOLE lot of times. The only thing I can figure is it's a tension spring to keep things from rattling. ::)
Offline 2linby
  • COG#: 5539
« Reply #15 on: March 11, 2012, 03:53:38 am »
Well if we had a spell check then I would not have misspelt it!    :nananana:
« Reply #16 on: March 11, 2012, 01:13:30 pm »
  SHEEEZZ GUYS!!   Get a life.  :1rij:  Waaahooo!!!
« Reply #17 on: March 11, 2012, 01:32:46 pm »
+1, if your missing the spring or the screw hole is stripped or whatever, you could probably accomplish the same thing with some peal-and-stick weather stripping.
Offline Frankshay
  • COG#: 9944
« Reply #18 on: March 11, 2012, 08:06:40 pm »
Thanks guys!
Offline CRocker
  • '02 C10 CDA # 416
« Reply #19 on: March 12, 2012, 01:42:21 am »
Thanks guys!
Wait!  Did this accomplish anything?  Or...did you just give up on this crowd?
Offline Frankshay
  • COG#: 9944
« Reply #20 on: March 12, 2012, 02:50:48 am »
A little of both!  I would have felt *really* crappy if that little metal thing had an obvious purpose!
Offline kd50
  • COG#: 10028
« Reply #21 on: March 12, 2012, 10:37:16 am »
I believe some have been on and around these things too long. Lots of us "new" guys have, what we feel are legit questions. I kind of got the same feeling when I asked about motor oil. I am sure we could search out our answers but I guess the only purpose of a forum is too post, communicate and share.
Wish I had an answer for you because I know how frustrating it can be to have spare parts or something you can not get together the way it came apart. Good luck
Kirk
'86 Concours totally custom just fer me!!
Offline rick3foxes
  • Apex, NC (USA)
« Reply #22 on: March 12, 2012, 12:44:29 pm »
Y'all can make fun all you want, but thanks to the title of this thread, I just realized there's another farkle I need.
A Spring Actuated Fairing Pocket Door Holdopener.
 >:D
IBA #34853
2012 Alaska Trip Video: http://www.youtube.com/watch?v=T578lzlENSY
2014 Western Trip Video: https://www.youtube.com/watch?v=VJgillo35KA
"...miles to go before I sleep."  - Robert Frost
Offline eldouble
« Reply #23 on: March 12, 2012, 04:20:38 pm »
 :truce:
But I still don't see a spring, nor remember one in there.
  • --2006 Concours--
« Reply #24 on: March 13, 2012, 12:05:25 am »
I'm wondering if previously afformentioned spring can be  modified to deliver an icy cold beverage...
Say a Soda Pop... (how sad)
