Author Topic: 12 volt plug  (Read 272 times)
Offline dimetraveler
  • COG#: 11100
12 volt plug
« on: April 05, 2019, 06:00:28 pm »
Have a 99 c10 and was wondering on the extra factory electrical leads under the left inner fairing behind storage pocket which is the hot the black and green or the other one? if anybody could tell me that would be great.
WOW
Online MAN OF BLUES
Re: 12 volt plug
« Reply #1 on: April 05, 2019, 07:47:19 pm »
white/blue is positive + HOT
black/yellow is negative - Ground
same goes for the aux connections in the rear,
they should all be female "tubular socket/plug", and have rubber Insulation, that you "plug" a male Banana plug into.
don't know where your are seeing a black/green combo wire up there... :truce: :??:
« Last Edit: April 05, 2019, 08:00:51 pm by MAN OF BLUES »
Offline 4Bikes
Re: 12 volt plug
« Reply #2 on: April 05, 2019, 10:35:52 pm »
Bill,
Good to hear from you. You should run another ride something like the ride you hosted a few years ago. The roads around your neighborhood in the Endless Mountains were awesome. I’ll help you set it up on the calendar if you are interested. Your place is not that far from the Williamsport National. Are you going?
Offline connieklr
  • COG#: 1608
Re: 12 volt plug
« Reply #3 on: April 06, 2019, 09:32:47 am »
Let's try female "bullet" connectors (4 mm). Banana plugs are for the test bench.   :-[
________________
Guy Young
COG #1608
COG Life Member
Semi-Civilian
GB Young Services, LLC
Offline RWulf
  • COG#: 7122
Re: 12 volt plug
« Reply #4 on: April 06, 2019, 02:12:17 pm »
I've allways call that style plug, SAE bullet connectors. You can go to
an auto parts store and get a trailer plug with pig tail wires already attached.
  • COG#: 11100
Re: 12 volt plug
« Reply #5 on: April 06, 2019, 03:50:56 pm »
Man of Blues my bad it would help if i wasn't color blind,had them hooked up the wrong way,just switched them. thanks
WOW
Offline S Smith
  • Northeast Area Director
  • COG#: 3184
Re: 12 volt plug
« Reply #6 on: April 07, 2019, 01:01:03 pm »
... it would help if i wasn't color blind,had them hooked up the wrong way,just switched them. thanks
When working with DC volts and in doubt of polarity, use a voltmeter.  An incorrect guess will yield a negative voltage reading.
 :iagree:
