Author Topic: 1991 C10 speed test  (Read 2512 times)
Offline DangerousDan
  • Deer Magnet Dan
1991 C10 speed test
« on: October 22, 2018, 04:27:23 am »
hello everyone.  Curious if anyone pushing their old c10 past 120 gets the sensation that the faring begins blowing you around?  At 125 mph I had to let up, but it seemed to still be accelerating  with good pull.   It was anything but smooth above 120, infact it was downright scary and I had to flex all my muscles instinctively to limit the buffeting I was experiencing.  I know it could have gone faster had the old windshield not seemed ready to break.  I have brand new tires and my "new to me" C10 " runs amazingly otherwise.
Re: 1991 C10 speed test
« Reply #1 on: October 22, 2018, 09:53:33 am »
« Reply #2 on: October 22, 2018, 12:49:26 pm »
  Here is some videos and info you should read.
https://sites.google.com/site/shoodabenengineering/
          http://www.cog-online.org/clubportal/ClubStatic.cfm?clubID=1328&pubmenuoptID=19722
https://www.youtube.com/watch?v=4W6k3pTdAXw&feature=plcp
  And make damn sure you have or get carb overflow tubes. Read about hydrolock and how it can wreak you engine.
   And welcome to the forum. The C10 is a great bike. Have had mine for 24 yrs and it still runs great. But I have done a lot of upgrades that make it a GREAT bike!! :) :)
  Welcome to the forum and sounds like you have a great C10. :great:  Enjoy!!!
« Last Edit: October 22, 2018, 12:52:46 pm by Mettler1 »
Offline mnbikeguy
« Reply #3 on: October 22, 2018, 10:47:55 pm »
Sure, it is a concern but honestly the OP didn't ask anything related to HL or fuel.
« Reply #4 on: October 23, 2018, 12:06:18 am »
  You are right!! Just hate to see a great running C10 ruined by a hydrolock episode. :'(
Offline Kelly E
  • Geriatric Hooligan
« Reply #5 on: October 23, 2018, 12:16:52 am »
Where in the Northwest are you Dan? I have had mine up around 115 or so but I have a 19" Clearview because I am short and it was a lot of wind noise but fairly smooth. I don't stay at that speed very long, I'm not 21 anymore. :'( :)
1994 Kawasaki ZG1000A-The Long Rider
1984 Honda VF700S Sabre-The Bike
1986 Honda CB700SC Nighthawk S The Hooligan Bike
1974 Honda CB550 K0
Offline Pbfoot
  • COG#: 10807
« Reply #6 on: October 23, 2018, 06:06:42 pm »
The soft front suspension is the root cause of Concours buffeting antics, especially at high speed imho. Many options to upgrade cheaply.
Offline JimBob
  • Woman...WHOAAAA MAN!
« Reply #7 on: October 25, 2018, 12:42:00 am »
This.
When I got mine it would get pushed around passing semi’s. Then read here about shortening the fork springs and putting in the pvc tubes, changing fork oil. Ever since much more stable with buffeting.
I’ve had it to about 120 and pretty stable (though never stayed there...I’m too old for that). 80/90 it’s very stable now.
« Reply #8 on: October 25, 2018, 09:36:27 am »
This.
How much did you shorten your springs?  How long were the spacers?  Ted cut 4 inches and thinks that was possibly too much.
Offline batboy
« Reply #9 on: October 25, 2018, 01:24:13 pm »
The first time I took a sprint to triple digits, I too backed off immediately from all the buffeting and harsh ride. I went with 1.0 Race Tech fork springs and 15w fork oil. Vast improvement. If you want to cut the stock springs, then however much you remove is how long the spacer should be (in other words, you need to be at the same length as the original stock spring, cut 2 inches, spacer needs to be 2 inches long). I've not done this, but I think Ted is suggesting try a small amount first and see how it works. If you need more, then cut a little more. If you cut too much the first time, then of course you can't go back.
1988 Kawasaki Concours ZG1000 Candy Persimmon Red
Bike has the usual accessories, upgrades, and modifications
Offline Stasch
  • COG#: 6830
« Reply #10 on: October 25, 2018, 02:03:37 pm »
My 2000 was very 'wandery' when I first got it, even at normal freeway speeds if following a semi truck as much as a half mile ahead of me.
A combination of fresh fork oil, different tires (no center groove) and turning in the OEM fork adjusters was all I've needed.  I don't run mine at triple digits often (but when I do . . . . . )
I've had mine up to 115 with a huge windshield and it was very stable.  I backed off when sudden visions of a police cruiser aiming a radar gun at me came to mind.
I'm not recommending 120 mph runs as it may cause nausea, vomiting, sudden bowel movements and the inability to control them . . . . but a free thing to try is firming up the front suspension with what you already have available.  While this may or may not be your end result, it could point you in the right direction and worth every penny to try.  :)
On the 94+ there are adjustment screws on top of each fork.  I can tell differences from adjusting those to firmer (screwed in) settings.
Since yours is a '91 this would be done with the air pressure (within OEM recommendations).
« Last Edit: October 25, 2018, 02:09:41 pm by Stasch »
Offline batboy
« Reply #11 on: October 25, 2018, 03:05:37 pm »
If you do use PVC pipe as spacers, then get the thick wall stuff (3/4" diameter schedule 80). Also, let's say you cut 2" off the stock spring and after testing you decide to cut another 2" off the spring, because it wasn't stiff enough for you yet, it's better to make a single spacer for each fork tube (i.e. don't use two 2" spacers, make a single 4" spacer).
« Reply #12 on: October 25, 2018, 03:14:55 pm »
fyi; On my 03' I did cut 4" {of the tightly wound coils} from a set of Progressive (brand) Fork Springs. (Not the stock springs)
      I installed a 4" spacer in the forks and did not screw the pre-load adjusters down..
      This worked fine for my nephew {250*}, but is a bit too stiff for me {210*}.
My intention is to shorten my spacers to 3 1/2", use no preload for me, and add 1/2" preload adjustment for my nephew.
ie; With 4" spacers and no preload, my spring sag {with me on the bike} is set at 35mm. {which is pretty stiff for the road}…
     With the shorter spacers, I can use "preload" adjustments to adjust the sag to anywhere I want it..
Before doing this, I'm thinking about adding Fork Emulators.
                                               :threadjack:
On my 86', I once reached 130 {indicated}.
On my 03', I was only able to get to about 125 {indicated}..
  Both tests had stock shield, trunk, and side bags..
  Didn't notice any major wobbles...
I'm now older/wiser; On my 14', I never {err} rarely exceed the speed limit...  ::)
                               I kept the 03' for others to ride, and for tinkering...  :great:
« Last Edit: October 28, 2018, 01:29:06 pm by connie_rider »
Offline JimBob
« Reply #13 on: October 28, 2018, 02:30:47 am »
Bud, it’s been a while, what I recall is I did the minimum cut thinking I could do the longer cut later. There’s a post about the process (if anyone can find it?) that I followed in about 2012.
I wish I’d cut more out - it’s still a little “divey” and soft for my weight (I’m 185). It’s especially soft under braking with 2 up. But that’s just my opinion for how I like things. I lean toward a little more firm, because, well, it’s not a car, it’ll never be that comfortable, so I may as well get some handling. And preventing dive for 2 up is a comfort factor.
  • Deer Magnet Dan
« Reply #14 on: November 15, 2018, 03:51:26 am »
Can't tell you how much I love this.  Smooth air!
https://madstad.com/collections/kawasaki/products/kawasaki-concours-1000-1986-up
Wow,, that will be my tax return present to self this year, ,thanx man, perfect !
  • Deer Magnet Dan
« Reply #15 on: November 15, 2018, 04:15:16 am »
I installed a manual shut off at the tank, and I never forget.  In fact, I'm obsessed with turning the fuel on and off ;) now, thanx for the heads up to all new c10 owners,, what a nightmare that would be to me.
  • Deer Magnet Dan
« Reply #16 on: November 15, 2018, 04:21:42 am »
Im in Cave Junction Oregon, right on the California Oregon border, 40 minutes from the ocean (awesome ride through the redwoods) , near Crescent City.  I'm beginning to look for some local people who do anual tours, I've never done one,, and my kids are old enough to enjoy my being gone for a few days now ;).
  • Deer Magnet Dan
« Reply #17 on: November 15, 2018, 04:57:53 am »
Ok,, for the record, I learned that previous owner went with the dunlop 120 front tire, which is not intended for that rim (2.5"),, should be a 110, and it slightly deforms into an egg shape instead of being round as it should be (gets taller and narrower than it should be).  Plus the center groove in the tire, riding on a very narrow egg like edge explains a lot.  My wind screen is cracked badly now (LOL spider webbed)  around the mounting screws, specially the outer most two.  A couple screws were missing in the full faring, and I'll check the air shocks for equality tomorrow morning.  I don't find any problem with diving from braking  though, I find them quite resistant in fact, suspecting the previous owner has done some modding besides the cruiser pegs, and seat.
  Also, to be clear, my c10 rides very smoothly at 100 or 110 mph, I can ride with no hands.   Its only at extreme speeds,, coming out of fourth gear at about 10 or 11 grand, hitting fifth, it is still pulling very hard, but the wind buffeting between 125 or 130 scares me to backing off, long before the old girl is done accelerating through fifth gear.   Oh,, and Im on the short straights and curving Redwood highway doing my speed tests, so not much time to watch the speedo, which is bouncing all over above 120, which seems to be the upper limit of 4th gear, 115 ish or so.  I already replaced missing screws and rubber washers, hopefully that helps to.
  • Deer Magnet Dan
« Reply #18 on: November 15, 2018, 05:21:26 am »
This.
hehe,, 80 or 90 is my average cruising speed ;), not many police out here, and lots of winding mountain roads.my radar detector is always on the lookout though.  I have noticed that any time I pass a car, im well over 100 mph, sometimes 120 ;), can't help it, that damn bike makes me do it >:(
« Reply #19 on: November 15, 2018, 10:51:08 am »
This.
I've done my share of speeding to be sure, but keep this in mind.  My first speeding ticket in 1976 (age 16) was a 92 in a 55 in Kirksville, MO (out of state).  Had to go to the cop shop downtown and have my father come get me.  $201.50!  That might be a tad more expensive these days.  Just something to think about. ;)
« Reply #20 on: November 15, 2018, 11:53:24 am »
   uhhh... no. The engine isn't even close to accelerating between 10 and 11 grand. Even with zx cams it isn't.
   I ran into the indicated mid 140's with Shoodaben. The 110 tire did give proper speedo mph on the gps, at least around 80 mph. Shoodaben was still accelerating but was certainly slowing, I was done, even though the suspension opgraded the buffeting had the bike dancing and getting scary.
  BTW, I was riding with other COGGERS when this occurred, so there are living witnesses that a c-10 can go kinda fast.   :-\ Steve
Offline bajasam
« Reply #21 on: November 15, 2018, 02:23:06 pm »
so dan, what kind of radar detector you using and does it give adequate warning at 100mph. i came within a short hair of passing a highway patrolman doing 95(he was only about 65) but saw him in the corner of my vision on a 3 lane freeway at the last second.would be nice to have had some warning of some type.
Offline Boomer
  • Me dwarfing Vivian
    • Boomers GTR Site
« Reply #22 on: November 15, 2018, 08:07:30 pm »
My best on my '86 was nearly 155mph indicated. Probably closer to 140mph real speed. Was done with the OEM screen, no sidebags, and no trunk. She's faster in 5th gear than 6th, but ya have to rag the motor to near the redline. Decent tyres and suspension makes a big difference.
George "Boomer" Garratt
Wickford, UK
CDA-007
  • Deer Magnet Dan
« Reply #23 on: November 18, 2018, 12:16:04 am »
I took all the lower farings off for an issue I was having and noticed,, I have a left front leaky seal in my forks ;(
  • Deer Magnet Dan
« Reply #24 on: November 18, 2018, 01:14:02 am »
just a cheap cobra 14 band, but i have the advantage of home turf in the wilderness out here and know most places police go,, and can hide and still get a ping on you, mostly, its just in-case I'm not paying enough attention .  The thing has alerted me 3 times now in Cave junction, long before I saw him, but I was going slow, as always in town. We don't have a patrol out here, the people of Cave Junction vote down the levies year after year,, so they stop patrolling and the nearest station is 30 miles from my turf.  I don't recommend anyone bank of radar detector,, but they help.
