Author Topic: 1994 Kawasaki ZG1000-A9 Engine swap (upgrade)  (Read 1095 times)
Offline tercopete
  • New Rider wiith 94 zg1000
« on: November 10, 2017, 03:09:33 pm »
can anyone tell me up to what year model engine can i swap/upgrade too if I have a 1994-A9 that i can use the same parts such as alternator, starter, shaft drive etc and that the engine alignment is the same as a 94 but only a newer engine
Offline Outback Jon
  • COG#: 9506
Re: 1994 Kawasaki ZG1000-A9 Engine swap (upgrade)
« Reply #1 on: November 10, 2017, 04:23:19 pm »
You're pretty much limited to the same engine from a 1986~2006 Concours.  There are no easy upgrades.  A ZRX1200 motor can be made to work, but the work includes custom fabbing some parts.
« Reply #2 on: November 10, 2017, 06:20:15 pm »
Don't be hung up on the word 'newer', as a good older engine beats a bad newer engine any day.
Even a high mileage, older engine that is in good condition might be better than a low mileage, newer engine that has been thrashed, or not cared for, or hydro-locked.
Offline drumstyx
  • COG#: 12290
« Reply #3 on: November 10, 2017, 08:00:35 pm »
86-06 will all work, 86 apparently had some issues with tuliping valves. Starter, alternator, etc apparently are all the same
« Reply #4 on: November 13, 2017, 02:05:59 pm »
Any year C-10 motor will work.
There are a few others that can be made to work, but {I think} all require changing the motor from chain to driveshaft...
If your looking for more power, the C-10 motor can be modified easier than changing to another engine.
Offline tercopete
« Reply #5 on: December 06, 2017, 08:17:43 pm »
Well i was able to get a complete1988 concours so im gonna switch motors when the weather gets warmer;  any warning or advice i should know???? and how many engine mount screws?
Offline Stasch
  • COG#: 6830
« Reply #6 on: December 11, 2017, 03:12:59 am »
A good repair manual will be a great help for your project.
There are 4 engine mount bolts.
Also:
Be discriminate with any rubber bits and anything that seals since you are dealing with a 30 year old engine.
While not an exhaustive list, some things I can recall off hand to preventatively replace / service before / during engine install, since you'll have easy access to them:
- Check / replace clutch star springs.
- Check alternator chain and alternator chain tensioner (ACT) integrity.
- Replace mount bolts for the side stand switch.  I changed mine from hex head to lower profile standard bolt heads.  OEM hex heads required header and / or center stand removal IIRC just to remove side stand switch.
- Coolant log and T-stat O-rings.  (While in bike, front log requires header and radiator removal to get at.  Rear log and T-stat requires carb bank removal.)
- Seals for water pump (3), shift shaft, clutch push rod and balancer shaft.
- neutral switch and oil pressure switch washers.
- Oil lines washers.
- Any gaskets showing signs of leaks.
- Radiator hoses.
- Do your first valve adjust before installation.  Super easy with engine on the bench and everything already out of the way.
- get any needed carb servicing done before you put the bank back in.
Offline 2wheelrush
  • COG#: 7992
« Reply #7 on: December 12, 2017, 01:51:05 am »
Good info Stasch. Going to go one soon.
