Author Topic: 2004 C10 smoking heavily under acceleration  (Read 1748 times)
Offline Bikerman
Re: 2004 C10 smoking heavily under acceleration
« Reply #50 on: November 02, 2018, 03:47:59 pm »
OK, I'm recovered enough from my injury to get it on my lift again and start tearing into it this weekend. I'm actually looking forward to it as a mystery, and I'm hopeful, especially based on Steve's previous comments. Thanks again to all.
« Reply #51 on: November 02, 2018, 10:45:22 pm »
After recovering from my surgery today (injured myself moving the Connie yesterday, as I am kind of little and getting old....), I will give it a shot. Thank you again to everyone.
  You ain't the only one getting too old to move a C10 around but I keep her around to remind me of the GREAT rides I have had with my C10. Wife gets a little jealous though !!
Offline Bikerman
« Reply #52 on: November 04, 2018, 01:05:02 pm »
Update: I pulled the valve cover yesterday and found a broken intake rocker arm on #3 (probably due to someone not properly tightening the adjuster lock nut) , a dropped intake valve in that same cylinder and what appears to be a hole in the piston (hard to see). The rest looks OK. I am pulling the head today for a better look. Looks like used parts are plentiful and cheap, making an top-end repair (used loaded head, poss. cylinders and a piston) in my future. If anyone wants to make me a great deal on those parts, please let me know!
« Reply #53 on: November 04, 2018, 01:50:34 pm »
 I know it's a crap shoot but plenty of used parts here.
https://www.ebay.com/sch/171107/i.html?_nkw=kawasaki+zg1000&_from=R40
    Good luck. Hope you get her back on the road again.  :great:
« Reply #54 on: November 04, 2018, 06:26:43 pm »
Let's not forget COG's own Jerry http://forum.cog-online.org/profile/?u=40419 Gaither.....aka The Wizard.  If he doesn't have it, he'll help you find one.
Offline Bikerman
« Reply #55 on: November 16, 2018, 02:39:17 am »
Progress to date: the top end is torn down. It was actually pretty easy after all the Tupperware came off. I think removing the carbs was acrually harder than the motor work so far.
Head and cylinders are off, #3 intake rocker is broken, #3 intake and exhaust valves are wiped out as well as the head in that same cylinder. #3 piston has a hole. #3 cylinder has extremely minor scarring that should hone out with minor loss of material, not over-bore. All missing bits found in strainer when I dropped the pan. Cams look good, as do the connecting rods, other cylinders and pistons. Crank case flushed with kerosene a couple of times with nothing else coming out.
-Bought a used head and piston off of a 93' for $40 shipped. 18K miles. Lots of 86' heads out there; I avoided due to weak valve issues.
-Bought new base and head gaskets for $35 by shopping the deals on-line. OEM and Cometic
-Bought OEM new rings for #3 piston for $26, stock size as I am not going to over-bore
-New circlips for the piston were $2.99
Amazingly, I think I will have the top end repaired and get the old girl back together for under $200 inc. fluids. A worthy winter project for sure, as our riding weather is now officially over.
Offline Pbfoot
  • COG#: 10807
« Reply #56 on: November 16, 2018, 02:45:03 pm »
Sweet!
Online connie_rider
« Reply #57 on: November 16, 2018, 05:34:08 pm »
Sounds really promising.
Where did you find the gaskets for such a low price?
I thought a head gasket cost far more that that..
« Reply #58 on: November 16, 2018, 07:59:06 pm »
... #3 piston has a hole. #3 cylinder has extremely minor scarring that should hone out with minor loss of material, not over-bore. ...
-Bought a used head and piston off of a 93' for $40 shipped. 18K miles. ...
when you get to putting this all back in, make sure to closely measure all the stuff, with proper measuring tools, piston/rings/cylinder (before-during-and after the hone), and specifically the "new" rings end gaps... they will likely need to be filed/adjusted to achieve the proper gap...this is common when new rings are purchased, and very necessary; also the orientation and inspection of the pistons ring grooves/placement of the new rings...
That one step means a great deal between success and pain on a rebuild.
best of luck
« Reply #59 on: November 16, 2018, 10:23:16 pm »
If you run the back tire onto a board it is easier to put the thing on the center stand. There is a video floating around where a guy put a C10 on the center stand in his bare feet. Heal quickly because it sounds like a real PITA.  ;)
