Author Topic: 7th Gear Mod  (Read 3437 times)
Offline Roger 123
  • COG#: 5903
7th Gear Mod
« on: July 03, 2008, 07:27:00 pm »
Had an interesting day today.    Paul King (who owns my old Connie) had put the 7th gear mod on a few weeks ago.  Well come to find out he really isn't happy with the bike (too big) so he's going to sell it.  Another local rider (Tom Hoffiss) bought the 7th gear from him.    So today we pulled Toms bevel drive and put Pauls 7th gear in it, then rode over to Pauls and put Tom's "factory" bevel gear in Pauls bike (Paul had pulled his dive yesterday).    Started at 0900 and finished up the first bike at 1330, rode over to Pauls and got his done as well by about 1700.    That drive is really nice, I highly recommend it, the bike is much smoother.    It's a small chore to swap but anyone who's pretty competant with a wrench can pull it off.  No special tools are required.  Roger  COG 5903  Virginia Beach, VA
Roger '14 Tenere ES, COG 5903, VA Beach, VA
Offline Tommyhof
  • COG#: 6517
7th Gear Mod
« Reply #1 on: July 08, 2008, 03:17:00 pm »
Roger is to modest, I think you really need to know the difference between a phillips and flat head to do this, way beyond my talents, it's not rocket science, but you need to have some wrench time under your belt.  As always Roger, a big thanks, I don't know what I would do without COG, well I guess I would be spending a lot of money at the dealers..............
Virginia Beach, VA
COG 6517
14 VStrom 1K
USN Retired
Offline Colin
  • I'd rather be riding!
    • Facebook
7th Gear Mod
« Reply #2 on: July 08, 2008, 08:28:00 pm »
+1 on the 7th gear mod, I love mine.  But I also love the light weight ZX10B rods and ZRX11 pistons too  ;p  Colin Prior  Cogmos Committee Chairman  Lake Forest Park WA  COG#7767  [IMG]http://thumb12.webshots.net/t/69/469/7/14/34/2606714340100596652OGFlOW
Colin Prior
Offline Roger 123
  • COG#: 5903
7th Gear Mod
« Reply #3 on: July 08, 2008, 08:50:00 pm »
If you do this mod make sure you put some lock-tight on the bevel drive bolts.  You might get an oil leak if you don't :mad:  Roger  COG 5903  Virginia Beach, VA
7th Gear Mod
« Reply #4 on: July 09, 2008, 10:19:00 pm »
   Roger means the bolts that bolt the bevel drive unit onto the engine case, not anything in the drive assy. The reason is that some of the threaded holes go into the crankcase, and oil can work it's way up the threads and out on your shiny new bevel drive housing.      Personally, I use black rtv instead of locktite all over my bike - it will prevent loosening, prevent seapage, prevent electrolysis from locking the bolt, and makes the bolt easy to remove. Steve   Shleper of the 7th gear unit and performance exhaust cam sprockets.       My bike - "SHOODABEN" - 1109cc's of what an 04 concours "shoodaben"!
Offline Roger 123
  • COG#: 5903
7th Gear Mod
« Reply #5 on: July 10, 2008, 06:39:00 am »
Steve's got it right (of course).  I knew better than to not put any sealer on those bolts, I guess it was just one of those things.  Absolutely my fault.    I did it the other two times I've done this, not sure why I brainfarted on this one!!    Anyway, all is well, great job on this upgrade!!  Roger  COG 5903  Virginia Beach, VA
Offline Jerry_Layman_NE
  • COG#: 1374
7th Gear Mod
« Reply #6 on: July 10, 2008, 11:30:00 am »
I'm just trying to understand this mod, so forgive me if I sound like a dummy. A "7th gear" tells me that this modification lives in the transmission, yet as I understand it, the mod involves a rear diff swap. Correct? So what exactly is this? A two speed rear end? Or just taller gears? A two speed rear end would make it a 12 gear mod and taller gears would still be only 6 gears. What am I missing?    Thanks for not laughing at me.
Jerry Layman  COG 1374
Fremont Nebraska
Offline Gerry B
  • Condoms prevent minivans!
  • COG#: 6037
7th Gear Mod
« Reply #7 on: July 10, 2008, 11:55:00 am »
It's not really an additional gear.  I'll give you a quick synopsis, Many Connie riders report trying to shift one more time after they are in 6th gear hoping to find "the elusive 7th gear". They (including me) are trying to get lower RPMS for cruising.  Along comes ace mechanic "Steve from Sunny Florida" who developed a method to change the gearing in the bevel drive. It lowers the RPMS and provides the psychological "7th gear" sound people were looking for.  There, and I'm not laughing at you either...My dog was, but I assure you, I wasn't! Enjoy!
« Last Edit: July 10, 2008, 11:56:00 am by Gerry B »
Gerry Barnett
Enfield, CT
COG 6037
Offline dawgwhat
7th Gear Mod
« Reply #8 on: July 10, 2008, 01:54:00 pm »
    Steve's got it right (of course).  I knew better than to not put any sealer on those bolts, I guess it was just one of those things.  Absolutely my fault.    I did it the other two times I've done this, not sure why I brainfarted on this one!!    Anyway, all is well, great job on this upgrade!!    Roger  COG 5903  Virginia Beach, VA    Tom got an oil leak and I had to go over and fix it  :p    don't feel bad about the brain fart thing   I rode my ( yours ) connie for 2k miles and forgot to put the inside baffles in at the faring  man was that bike hot  :gasp:
Paul King  COG 7578  CDA 0124
Offline kwn306
  • COG#: 6049
7th Gear Mod
« Reply #9 on: July 11, 2008, 08:19:00 am »
Some of us consider him "Steve from Sunny FL" others consider him "Bubba the Motorcycle Mechnix" ;)    Kurt & Sue Nordstrom  Spotsylvania, VA  COG 6049 & 6049A  VA & WV Assistant Area Directors
« Last Edit: July 11, 2008, 08:19:00 am by kwn306 »
Kurt Nordstrom  Spotsylvania, VA  COG 6049
This message has been sent from the voices in my head and transcribed by their drinking buddy.
Rain, Snow, Sleet, or Shine, caged or in the wind, I'll see ya there.
Offline 2linby
  • I rode today, did you?
  • COG#: 5539
7th Gear Mod
« Reply #10 on: July 11, 2008, 11:05:00 am »
Meknic, meknic!  AKA "2linby" That's 2-lin-by folks!  Northwest Area Director  COG #5539  AMA #927779  IBA #15034  Team Oregon MC Instructor    http://community.webshots.com/user/2linby  http://tinyurl.com/njas8 (IBA BunBurner Gold Trip)  http://tinyurl.com/lwelx (Alaska trip)
7th Gear Mod
« Reply #11 on: July 11, 2008, 01:40:00 pm »
No it's actually "bubba the lonmowr mekanik"      There'a few around who may even remember how I got that moniker. I expect Bob is one! Steve     Shleper of the 7th gear unit and performance exhaust cam sprockets.       My bike - "SHOODABEN" - 1109cc's of what an 04 concours "shoodaben"!
« Last Edit: July 11, 2008, 01:41:00 pm by Steve in Sunny Fla »
Offline Nosmo
7th Gear Mod
« Reply #12 on: July 11, 2008, 02:43:00 pm »
Jerry:    The "7th gear mod" is a change to the bevel drive gear assembly that comes off the transmission on the left side of the case, it's that big bulge that your left ankle rubs on.  (This housing assembly contains the oil sight gage, and the shifter shaft goes through it.)  There are no changes to the rear end.  It does not actually add another gear, just changes the ratios so that it's like having that elusive "7th gear" that we all seem to look for.  Steve takes the old units and changes out the drive gear for one that is slightly larger and the driven gear for one that is slightly smaller, which changes the final drive ratio so the engine turns approximatley 12% slower in relation to the rear wheel.  This drops the engine RPM at 65 MPH from about 4000 RPM to about 3520.  Makes the bike a whole new thing.  Reduces noise, vibration, rider fatigue, etc.  Also gives you better usability in the middle gears when pounding the backroads, in my opinion.  IT IS THE BEST THING YOU WILL EVER ADD TO YOUR CONNIE! It is a fairly simple remove and replace procedure.  You remove the rear wheel, shock, swing arm, drive shaft, water pump (you neeed to change your coolant anyway, right?), clutch slave cylinder, (don't disconnect the fluid hose), remove the bevel gear housing (you should have a good service manual for torques, etc), then install the new unit and re-install all the above.  Steve will sell you an exchange unit or he will rework yours if you send it to him.  All work is top-notch and it looks like a new unit when you get it, he even supplies the new-style metal gasket for the housing.  And before you ask, no, you can't just get some gears and drop them in yourself.  There is machining work to the housing and gears involved and a big lot of thought and study went into this mod.  Steve is a genius for figuring this out.  He also has a kit for changing the exhaust and intake cam timing and you might want to do that too.  It gives more torque in the lower RPM's and is the final icing on the cake with the new gearing.  If you have average mechanical skills and stay relatively sober you can do this in a weekend no problem.   :)
2003 Connie    2007 Wee-Strom
