Author Topic: 95 C10 turn signal question  (Read 444 times)
Offline Bocajnala
« on: December 06, 2018, 02:48:51 am »
Ok, so here's the issue:
1995 Kawasaki C10. Left side rear turn signal is not working. It's not the bulb. I've replaced the bulb, and cleaned the connection there.
Everything else, all other lights etc are working fine.
I can't see anything wrong with the exposed wire.
What should I know before diving into this thing?
As always, thanks for all the help.
-Jake
Offline Harry Martin
  • ☺ Cartoonist ☺
  • Fear is not boring
    • Harry Martin Cartoons
  • COG#: 4090
Re: 95 C10 turn signal question
« Reply #1 on: December 06, 2018, 03:08:49 am »
-Jake
Exposed wire?
Where?
Offline Bocajnala
« Reply #2 on: December 06, 2018, 11:29:29 am »
Exposed wire was probably the wrong term. The little bit of wire I can see coming from the turn signal post, into the connection for the bulb appears to be in good condition.
-Jake
Offline Bocajnala
« Reply #3 on: December 06, 2018, 02:56:46 pm »
This is what we're looking at.
While we're here, does anybody know what that black push button is for?  It's under the seat, beneath the fender in that hollow area.
Thanks again
Online JimBob
  • Woman...WHOAAAA MAN!
« Reply #4 on: December 06, 2018, 04:01:11 pm »
No idea what the push button is for- someone added that. You’ll want to trace the wiring on that button to see what its all about.
The signal wires go up under the seat, in the back. Two bullet connectors. I’d disconnect those and put a volt meter/test light in them, see what you get when you hit the signal. If you’re getting power there, then something’s likely wrong with the signal itself, if not, something else is going on.
Offline Bocajnala
« Reply #5 on: December 06, 2018, 05:13:58 pm »
Ok I'll start there.
I'm currently out of town until Monday, but trying to get some ideas before I tear into it Monday.
Thanks for the info.
-Jake
Offline Bill Hookman
« Reply #6 on: December 06, 2018, 07:42:01 pm »
In addition to what Jimbob said, I don't know if they'll reach, but you might be able to swap the wires for the left and right and see it works on the other side and vice versa.  Also, does it flash with the 4-ways on?
Bill Hookman  Columbus, OH
The twistier and hillier the road, the bigger the smile.
Offline Bocajnala
« Reply #7 on: December 07, 2018, 01:36:23 am »
No it does not.
The other three work fine with the signal switch and the emergency lights, but the back left does not flash at all.
If I could swap wires side-to-side that would let me know if the wires were good up to that connection. If they reach, that will be helpful.
-Jake
Offline Victor Salisbury
  • COG#: 3673
« Reply #8 on: December 07, 2018, 11:34:34 am »
The rear left side turn signal is notorious for having corrosion issues. As the bike sits on the sidestand, any moisture the bike went thorug on a ride migrates down the turn stalk and sits. Many have taken to siliconing the end of the turn stalk, on the inside of the fender, to seal it off.  Yours looks pretty clean though on the outside, could be corroded in the socket underneath the pad with the bulb connections.
That button underneath the seat, thats an interesting one, no idea what purpose that would serve. I'd trace that back make sure it's not a factor somehow. weird.
Vic Salisbury
COG #3673
'97 Connie "The Grinch"
Sarasota, FL
www.cog-online.org
« Reply #9 on: December 07, 2018, 09:02:54 pm »
as Vic noted, it's common, and usually traced back to a corroded connection inside the base of the socket, where the wire is soldered to that "base contact", on the backside of the insulator. Or the actual Solder Blob on the front, either one...
Clean that contact with sandpaper, and also the inside of the socket walls, and spray some contact cleaner in and blow it all out with compressed air.
Actuate the 4 way flashers, and check for volts at the contacts using a VOM.
if no juice present, the wire is compromised behind the inner base of the socket, pick up a used one for a couple bucks on e-bay., or install some aftermarket ones...
oh, I forgot to mention, make sure the bulb you use is good, and the correct one... and scrub those connections on the bulb with sandpaper also..
I have to laugh a bit, one of the worst injuries I ever had working on these bikes, was from trying to replace a corroded in left rear turn signal bulb... the biotch "exploded" and shattered between my thumb and fingers when I was trying to get it removed...cut 2 fingers and my thumb. and bled like a stuck pig....and I had to pluck shards of glass outta the wounds... mamma that hurt.... :-\ :-\ :-\ :-[ :-[ :-[ :-[ :-[ :-[ :-[  I learned a lesson, always wear a leather glove, to remove a bulb like that... live and learn. :rotflmao: :rotflmao: :rotflmao: :rotflmao:
Offline Bocajnala
« Reply #10 on: December 07, 2018, 11:59:24 pm »
Good info so far, thank you all.
I have an idea of where to start next week when I get home.
I'll be sure to update what I find
-Jake
Offline JPD
  • COG#: 12064
« Reply #11 on: December 08, 2018, 01:17:36 pm »
All great info on the signal light socket, but I would still start with a VOM and the connection under the seat. If you don't have power at that point the fault is forward of that. If you have power then take the time to clean repair the socket or get a new one
Offline Bocajnala
« Reply #12 on: December 12, 2018, 12:03:57 am »
Well, I cleaned the socket with cleaner, the compressor and a small wire brush and got it working. Cleaned the other side just because. Got it all working.
Thanks everyone.
As for the push button, I didn't look too closely yet, but still no idea what it goes to.
Here a better picture of the push button.
