Author Topic: A few noon questions  (Read 859 times)
Offline Tjnoma99
  • COG#: 12686
« on: September 29, 2017, 12:14:59 am »
As I'm sure many you have noticed my many maintenance posts! I've owned my 2003 Connie for about a month. I've ridden her 6 miles! I know less about this bike than I do women ( ask my fiance how awesome I am  :-[ ). I've replaced : tires, a few engine gaskets, coolant, coolant orings, all fluids ( yes all), spark plugs and wires, throttle cables, a lot of electric wire madness, headlight adapter( previous owner cut it apart for an hid setup), cracked left fairing,battery, all screws for the fairings. I've done the free power mod, added a ground bus, added a farkel relay setup, valve adjustment, checked compression, carb cleaning and rejecting ( THANKS STEVE!), removed all the Cali emissions garbage, cleaned out the tank, and repainted her. Not too bad for a couple's down weeks and working 6 days a week!
So now that I get a chance to actually ride her I have a few questions- does the bike always have valve chatter? It's doesn't sound bad. Doesn't sound like anything is broken just wondering. 2- what size are the bolts that hold the fuel tank on? Guess I misplaced them ( my nice way of saying' dae gone!). And 3- with Murph headlight adapter- which wire ( accessory wires red and blue) is low beam?
Hopefully tomorrow I can finish these few thing and take her to work with me on Saturday!  Thanks for all the help so far!
Offline Pbfoot
  • COG#: 10807
Re: A few noon questions
« Reply #1 on: September 29, 2017, 12:22:44 am »
Wear earplugs. The C10 does sound a little agricultural.
« Last Edit: September 29, 2017, 12:40:48 am by Pbfoot »
Offline Tjnoma99
  • COG#: 12686
« Reply #2 on: September 29, 2017, 12:33:16 am »
I don't mind it just wondering. It's definitely the most quiet bike in my stable!
Offline Harry Martin
  • ☺ Cartoonist ☺
  • Fear is not boring
    • Harry Martin Cartoons
  • COG#: 4090
« Reply #3 on: September 29, 2017, 12:41:17 am »
Chain tensioner chatter?
Harry in Wild and Windy Casper, WY - 1986 Vintage "Silverdammit" - 2015 "Greendammit"
Freelance Cartoonist & Illustrator: Road Rash Motorcycle Cartoon Book
Offline Tjnoma99
  • COG#: 12686
« Reply #4 on: September 29, 2017, 12:51:12 am »
I'm almost positive it's valves. I have two big v twin bikes and it sounds similar to them. I just didn't expect this engine to have that sound. This is my first bike with this setup. I've been a v twin cruiser guy for years.
Offline roadisattva
  • ready to spend my good health and clean living dividend
  • enlightment is out there somewhere
  • COG#: 12200
« Reply #5 on: September 29, 2017, 01:14:38 am »
AG sound equals raising cane.  :))
Another Steve
Offline Old Man on a Connie
  • South West Area Director
  • COG#: 9932
« Reply #6 on: September 29, 2017, 01:48:00 am »
Bring it to Kernville. Then 6 guys can stand around an give you 6 different opinions  :) :beerchug:
"I don't always ride street bikes, but when I do, It's a Concours. A C14 '11 silver to be precise." OTP 2017 Traveler. It was a Blast Baby.
Offline Tjnoma99
  • COG#: 12686
« Reply #7 on: September 29, 2017, 01:51:39 am »
I'll know Sunday if I can make it! I want to be sure she's road worthy!  ;D
Offline Bob_C_CT
« Reply #8 on: September 29, 2017, 09:22:41 am »
Ok opportunity for a farkle, go to Murphs site and order the gas tank quick release. This kit replaces the tank hold down bolts. Those bolts you lost have gotten stripped and broken off by others before, not good?With the Bergmen's gas tank quick release kit from Murphkits once installed you just pull the pins out of the head of the stainless bolts and the tank comes off easier. Now I sound like a commercial but this farkle, in my opinion is worth every penny spent.
https://www.murphskits.com/index.php?cPath=1_95&osCsid=ipLieRvxKfkaqgRrGnZZA2
If you order the kit the instructions say you need to have the original spacers which you may not have, see instructions below
http://www.murphskits.com/catalog/docs/Quick%20Release%20Tank%20Kit.pdf
« Last Edit: September 29, 2017, 09:34:29 am by Bob_C_CT »
« Reply #9 on: September 29, 2017, 12:37:52 pm »
  One of the best items I ever bought for my C10!! :) :)
Offline m in sc
« Reply #10 on: September 29, 2017, 02:11:47 pm »
after adjusting mine, it developed a light 'flutter' i know they are adjusted to spec now, they were ALL tight when i first looked at it, and pretty sure at 34?k (i got it at 33k) i did the first valve adjustment in its life. it only does it at idle, and its really really minor. compared to every other bike i have, its pretty quiet (over all noise)     my dead stock KTM390... now THAT sounds like a freaking lawn tractor.   (speaking of agricultural sounds).
Offline GKreamer
  • COG#: 12323
« Reply #11 on: September 29, 2017, 10:40:19 pm »
I seem to recall reading here that chatty valves are happy valves and when they get quiet then they need adjusting.
If I'm wrong, correction will arrive swiftly!
Offline Nosmo
« Reply #12 on: September 29, 2017, 11:23:32 pm »
Yes, tappy is happy when it comes to valves.  Which must mean that mine are feaking' ECSTATIC! ;D
2003 Connie    2007 Wee-Strom
Offline Tjnoma99
  • COG#: 12686
« Reply #13 on: September 30, 2017, 12:13:56 am »
Ok. I'm feeling much better! I've never done a valve adjustment before. Just wanted to be safe!
Thank you every one!
Offline Max
    • Connie Photos
  • COG#: 8595
« Reply #14 on: September 30, 2017, 05:25:01 am »
Tank bolts are 6 x25 mm
-Robert M. Pirsig
Offline Tjnoma99
  • COG#: 12686
« Reply #15 on: September 30, 2017, 11:51:43 am »
Thanks max!
