Author Topic: Accessory switch panel!  (Read 260 times)
Offline Eric
« on: September 15, 2018, 09:04:53 pm »
Hey guys just thought I’d share what i just did! Hooked up a marine switch and USB port panel, just used the accessory wire under the fairing and ran a relay to the turn signal!
https://drive.google.com/open?id=18zSAPsBR2Z9ix0ZxSEMZVrGWFxYGz98Q
Offline kkja13
  • Tyler, TX
Re: Accessory switch panel!
« Reply #1 on: September 17, 2018, 03:32:18 pm »
Accessory wire?  Switched or constant 12v?
I ran a wire directly to the battery for my 12v outlet, so that I could charge the phone without the ignition on and plug in the tender to this port when needed.  Haven't needed that option, I ride year round!
2004 C10
2003 Suzuki SV650s
Offline Derick
    • BeginnerBikers.org
« Reply #2 on: September 17, 2018, 03:33:49 pm »
Have you ridden at night? I had a little blue LED on an accessory switch that I just picked up at oreillys......it was INSANELY bright, and was a terrible distraction at night. I will always go red.
Current Bikes:
Offline Bob_C_CT
« Reply #3 on: September 17, 2018, 04:58:56 pm »
I did the same all the time on socket so I can charge phone when bike is off and use outlet to charge battery.
Confirmed, I have a usb charger for my phone that I have in my truck. I had to use a backseat outlet because of the brightness of the blue light. It stop lights up the backseat.
Offline fred-houston
  • COG Membership Officer
  • COG#: 9066
« Reply #4 on: September 17, 2018, 05:34:48 pm »
I used used an Eastern Beaver fuse block.  Best of both worlds.
https://www.easternbeaver.com/Main/Wiring_Kits/Fuseboxes/PC-8/pc-8.html
Missouri City, TeXaS
1999 C-10 EFI (Semi Naked)
2016 Yamaha Super Tenere
