Author Topic: Air Injection System Removal  (Read 6964 times)
Offline connieklr
  • COG#: 1608
Re: Air Injection System Removal
« Reply #50 on: November 24, 2017, 12:34:44 pm »
If the air ports are tapped and plugged securely, why not make the block-off plate so that it lays in the recess of the valve cover where the reed valves were and flush with the top?  A couple of the reasons I've heard to install block-off plates is that it cleans up the area and makes it easier to remove the cover.  The plate could be held in with high temp adhesive of some sort.  With the current setup I have, you still end up taking those four bolts out to get max clearance to remove that pesky valve cover.  It would be more difficult to go back to stock, but it would give the most clearance come valve check time and also the cleanest look.
Appreciate the suggestion. I actually considered that, but decided on the full cover plates instead.
One of the reasons for going with the button head screws is because of their low profile. Whether they'll be low enough without removal? Guess we'll find out. If not, we'll see how much they interfere. I do have a little extra material so I can counterbore the holes slightly if need be.
________________
Guy Young
COG #1608
COG Life Member
Semi-Civilian
GB Young Services, LLC
Offline connieklr
  • COG#: 1608
« Reply #51 on: November 24, 2017, 01:12:01 pm »
And finally, my grousing about a local metals distributor no longer selling drops - no longer an elevated blood pressure issue for me.
Found out from a local biker friend (actually the fella I was doing the BSA crank work for, and making some bits for his drill mill), that a Metal Supermarkets (https://www.metalsupermarkets.com/richmond-virginia/) store is in town that specializes in material small quantities.
The place is right around the corner from where I (and MOB later) used to work, altho' they weren't around when I was there. MOB may have already known about the place - dunno. If he did, he didn't say anything.
Regardless, we're happy.
« Last Edit: November 24, 2017, 01:41:05 pm by connieklr »
________________
Guy Young
COG #1608
COG Life Member
Semi-Civilian
« Reply #52 on: November 24, 2017, 01:53:06 pm »
Bud, that gives me  an idea  (A project) for connieklr to consider..
Since he has the valve cover off anyway, has lots of free time, and just happens to have a mill with shavings already on it,,   >:D
Why not machine away the lip of the 2 ports before installing his covers??
No one else has that on their C-10...
I know I'd do it, if I just happened to have a mill and wanted to practice my skills,,, etc etc...   ;)
« Reply #53 on: November 24, 2017, 02:13:07 pm »
That sounds like a plan!  It's almost as much fun as spending someone else's money!   :)
Offline connieklr
  • COG#: 1608
« Reply #54 on: November 24, 2017, 03:07:45 pm »
Heck, IF I was going to go to that extreme, I'd machine off the lips of the ports, the flange areas of my pieces turning them into "slugs," and just weld those suckers up.
Oh darn - I'm almost out of argon. That project will just have to wait.............
________________
Guy Young
COG #1608
COG Life Member
Semi-Civilian
Offline connieklr
  • COG#: 1608
« Reply #55 on: November 24, 2017, 05:10:46 pm »
And yes, that is what I am finding. Even with the button head screws, I still had to remove the LH block off plate I made to get the valve cover in place.  ~2.5mm seems to make all the difference in the world, as are the hollow dowels, which I pulled out of the cover for additional clearance. They have always been a PITA on my bike.
The RH side cover can compress the coolant line. so it's really not a factor.
I'll play with this thing later, but time to shift gears. The HD croaked on my garage computer, new one just arrived, so it's game on for computer repair.
Always something.   :(
________________
Guy Young
COG #1608
COG Life Member
Semi-Civilian
Offline JimBob
  • Woman...WHOAAAA MAN!
« Reply #56 on: November 24, 2017, 07:47:46 pm »
That’s what I did, Bud - cut them out of some old aluminum scrap I had lying around, using a jig saw and then cleaned up using my dremel - sitting on the back step. Not super pretty, but with a quick shot of whatever black paint I had lying around, some gaskets made from a roll of material, and a few button-cap screws from the collection and other than time they were free. And I didn’t tap the head. That was thousands of miles ago and no leaks.
Offline Locomotiveman
  • COG#: 12297
« Reply #57 on: November 24, 2017, 09:33:49 pm »
Myself, I put the Block-off plates on for 3 basic reasons. 1. To free up precious space when pulling the cover. 2. Eliminating Ugliness, possible vacuum leaks and whatnot. 3. Simplify, simplify, simplify. I am puzzled why someone would NOT do it....   Locomotiveman
Not trying to get in anybodies face here but this is why I never did it on my C10s.
The system causes no penalty whatsoever to performance when functioning properly and reduces emissions by admitting fresh air into the exhaust system under relatively heavy acceleration to help pollutants burn before they reach the atmosphere. That's a win/win in my book.
It's more an Access thing... less clutter, less leaks, less hoses to fail, less oily air going hither and non.  It does NOT reduce emissions. It's a 'feel good' thingie. Kinda like charging an Electric Car with juice from a Power Plant, letting forests burn in a 'No Logging Zone', having Kenworth's haul recycled Glass to a landfill or horrid Rubber hose factories making anti-Smog hoses.  Let's agree to disagree...or not.
The way I see it is the benefits of removing the AIS don't outweigh the advantages of leaving it in, so I don't really understand why folk do it.
To each their own.  ;)
Offline connieklr
  • COG#: 1608
« Reply #58 on: November 24, 2017, 10:23:40 pm »
Not only can you be considered as "slave labor," but also a freakin' instigator.
After seeing that my skinny plates still were too high by an approx. 2.5mm for "easy" (Ha!!!) valve cover removal, I am seriously considering what you mentioned above - kinda, sorta.
The mill and surrounding area has already been cleaned up, but thinking of pulling out the set screws, cleaning up the yukky aluminum with a die grinder, and just welding up the holes. Once that's done, mill the cast lips around the reed area down to near the gasket surface then refit the plates I made. if I fook up - well - they're some out there that are relatively cheap.
I'll flip a coin and go from there.
On another note, new HD install seemed to go okay for the garage computer and I just need to install all the miscellaneous crap to make it fully usable for the stuff I do out there.
________________
Guy Young
COG #1608
COG Life Member
Semi-Civilian
  • COG#: 12297
« Reply #59 on: November 24, 2017, 11:57:37 pm »
Why didn't WE/ I  think of that... Milling down the covers. Brilliant.
Offline m in sc
« Reply #60 on: November 25, 2017, 04:27:39 pm »
why not use countersunk screws, even cleaner, and reduce some height?
Like said, mines still on, i see no issues with it. one reason i did leave it on, is since it draws air from the airbox, it will, in theory, also put a slightly cooler charge in the exhaust pipe. considering the propensity of these bikes melting the fans, i don't see this as a bad possible side effect.
(for those scratching their heads, NO i never thought it was part of the crankcase ventilation system, it was to gauge what kind of reaction would be given to an obviously incorrect answer by a certain member.  )
has anybody tested the egt with and without the air valves plugged vs open on the same bike?
Offline Brooke_Benfield_OR
  • COG#: 2185
« Reply #61 on: November 25, 2017, 05:25:17 pm »
That would have to be done while running down the road with a good load applied or on a dyno since no air is admitted into the exhaust until the intake manifold vacuum is low (open throttle).
I'd say the EGT should be higher with the air valves contributing air into the exhaust system.
Offline connieklr
  • COG#: 1608
« Reply #62 on: November 26, 2017, 11:22:47 am »
On my bike, as mentioned, the screws weren't the issue; it was the cover plates themselves. 2.5mm seems to make all the difference in the world. I'll either have to resign myself to the fact that at least one of the covers still has to come off, or really reduce the height of the pocket areas by machining them down.
________________
Guy Young
COG #1608
COG Life Member
Semi-Civilian
Offline Outback Jon
  • COG#: 9506
« Reply #63 on: November 26, 2017, 04:04:19 pm »
I have to remove one screw to get my valve cover off.  For some reason, that one (I think it is the leftmost one) just doesn't clear the frame.  All the others do.  Next time I remove the cover, I'm going to grind that screw down just enough to make it fit.
« Reply #64 on: November 26, 2017, 05:33:13 pm »
Or you could get a Canadian valve cover.
« Reply #65 on: November 26, 2017, 11:05:45 pm »
I wuz just suggesting you remove the top lip (approx. 2.5MM) and install your plates.
Not remove the whole thing and or weld it up.
But, I like your style....... {kinda}  :)
Hmmm, mebbe ya could use a fly cutter, remove the 2.5 mm lip,  and shave the fins/etc too???   :sign0137:
  {Would make the removal/installation a lot easier, "and" the shiny/unpainted fins would look cool.........}
« Last Edit: November 26, 2017, 11:10:11 pm by connie_rider »
Offline m in sc
« Reply #66 on: November 27, 2017, 07:53:34 pm »
[/quote]
[/quote]
explain your theory here. pulling cooler air into the exhaust will make the temps go up.. exaclty how? the fuel shouldn't be combusting in the exhaust system, if it is, its popping.
  • COG#: 2185
« Reply #67 on: November 28, 2017, 10:02:50 pm »
My theory is that there is some sort of chemical reaction that goes on in the exhaust system when fresh air is introduced that would make the temperature higher. I'd also say that there isn't very much raw fuel in the exhaust stream so the introduction of fresh air doesn't excite things to the level of creating a pop.
But...I don't actually know if the temperature ends up being elevated or diminished. It's just an opinion and worth everything I was paid for offering it.  ;D
Offline m in sc
« Reply #68 on: November 29, 2017, 05:24:34 am »
ok, so upon reading up on it, (in particular, the yamaha ais system being similar) yes.. it causes oxidation in the system, causing heat as a result. i stand corrected. i always thought the extra heat from catalyzed systems was from the converter restriction (on those equipped with), not the air pump.  but the air pump or air injection alone does cause it as well, like on the connie. Hm.  Now i know.  :beerchug:
Offline connieklr
  • COG#: 1608
« Reply #69 on: November 30, 2017, 03:07:06 pm »
I made it over to the potential new source for my metal needs this morning, and they had exactly what I was looking for earlier. They had an ~18" x 9" x 1/4" drop that just barely squeezed into the aluminum pannier on my KLR. Price was just a tad over $15. We're happy.
The folks are super nice too and they have a SL of stuff in their warehouse. I'll be back, but not today. I got what I needed for now.
________________
Guy Young
COG #1608
COG Life Member
Semi-Civilian
« Reply #70 on: November 30, 2017, 03:17:20 pm »
OK, what are ya building now??
Offline connieklr
  • COG#: 1608
« Reply #71 on: November 30, 2017, 04:28:53 pm »
Uh, spares. Yeah, that's the ticket, spares.   :rotflmao:
________________
Guy Young
COG #1608
COG Life Member
Semi-Civilian
Offline connieklr
  • COG#: 1608
« Reply #72 on: November 30, 2017, 04:31:16 pm »
I suppose this might be considered a little overkill for the plug where the airline came out of the air box, huh?
Seriously, I looked in the box and a couple of hardware stores and couldn't find one that was the correct size with the grommet removed.... and duct tape just wasn't gonna cut it..... figured it'd come loose anyway. So, fire up the lathe and crank one out. Turned it so it is a firm fit, but secured it anyway with some Permatex Gasket Maker RTV. She ain't going no where.
« Last Edit: November 30, 2017, 05:16:54 pm by connieklr »
________________
Guy Young
COG #1608
COG Life Member
Semi-Civilian
Offline m in sc
« Reply #73 on: November 30, 2017, 04:40:11 pm »
looks right to me.  :great: was thinking of that this morning, might do this in the spring when the weather warms up to reduce exhaust heat. was a welcome feeling this morning though on the way into work.
« Reply #74 on: November 30, 2017, 04:55:35 pm »
Iiiii "LIKE IT"!!!
