Author Topic: As Close to Plug n Play As You'll Get for a 17" Wheel  (Read 4280 times)
Offline JDM
  • COG#: 8877
« on: June 16, 2016, 09:54:00 pm »
This is as close to plug and play as you will get to installing a 17" rear wheel.
1- you will need a Mean Streak wheel from a Vulcan 1500 or 1600
2- you will need a front rotor from a Vulcan Nomad year 99/04
3- you will need a longer axle spacer Moma Kaw pn 92027-1752 shortened to 28.5 mm.
Photo 1- shows the existing rear wheel before the modifications.
Photo 2- shows the existing caliper bracket.
Photo 3- shows the existing bracket after it is modified.
Photo 4- shows the new rear wheel bolted in place with the brake assembly reinstalled, and ready to ride.
If you look close at photo no. 2, you will see the caliper bracket is wider at the bottom than it is at the top. You will need to grind off the inside bottom face as shown approximately 8 mm +/_ .
You will need to shorten the axle spacer to 28.5 mm +/_.
You will need to reassemble the rear wheel on the punkin. Loosen the front bolt that holds the brake compression rod, lift it up out of the way, and reinstall the spacer and brake caliper plate along with the spindle bolt "axle". After you have the wheel on and snugged up, reinstall the brakes and compression arm, recheck that you have every thing tight, and the wheel turns freely and the brakes work.
HTH,
​JD​
Offline kkja13
  • Tyler, TX
Re: As Close to Plug n Play As You'll Get for a 17" Wheel
« Reply #1 on: June 17, 2016, 03:17:58 am »
No wheel machining required?
2004 C10
2003 Suzuki SV650s
Offline Bradley
« Reply #2 on: June 17, 2016, 04:21:26 am »
I've already got my MS wheel machined and mounted.  But this would have been easier, and probably cheaper than getting the wheel machined.  What bike is the spacer from?
The wheel is machined .300 inches, which is 7.62mm.  So 8mm is close enough.
Offline Pbfoot
  • COG#: 10807
« Reply #3 on: June 17, 2016, 11:05:46 am »
I am concerned that hand grinding the caliper bracket would make it out of square. I would have it machined.
« Reply #4 on: June 17, 2016, 12:43:10 pm »
There's no reason hand work can't be as precise as a machine, for something as simple as this. Just take your time and check your work often.
Offline Nosmo
« Reply #5 on: June 17, 2016, 07:13:55 pm »
+1    Remember...hands built the machines that built the machines that built the machines......
2003 Connie    2007 Wee-Strom
Offline Sparkie
« Reply #6 on: June 18, 2016, 05:17:25 pm »
I'm curious how much clearance between the brake caliper and rt side case there is now?  If I understand correctly with this mod the brake caliper is shifting to the right a little.  Mark
2006 Kawasaki Concours (Sold)
2006 Ducati 620 Multistrada
2016 Yamaha FJR 1300A
Offline turbo-max
  • COG#: 10445
« Reply #7 on: June 18, 2016, 07:35:12 pm »
i cut mine twice and it's still too short...what gives?  :??:
99 c-10 "the purple monster"
  • COG#: 13095
« Reply #8 on: June 18, 2016, 10:47:20 pm »
Good idea. Well done  :)
Offline tonyb
  • COG#: 11907
« Reply #9 on: June 21, 2016, 01:08:09 am »
JD,
In Photo 4, it looks like the OUTSIDE of the caliper bracket (the face which contacts the swing arm) has been shaved which is what I would expect, in order to move the caliper 8 mm outboard. Seems at odds with photo 3.
Comment?
Offline JDM
  • COG#: 8877
« Reply #10 on: June 21, 2016, 01:47:39 am »
JD,
Comment?
You only need to shave the inside face of the caliper bracket by 8+ mm. The Vulcan Nomad rotor is thinner than the existing ZG1000 rotor. If you will follow the procedure that is outlined in the original post, you will find that everything fits like a glove making this a very easy modification. Here are two more photos   that will give you an indication on what you are dealing with. HTH, JD
Offline JDM
  • COG#: 8877
« Reply #11 on: June 21, 2016, 01:50:27 am »
See my response and photos to tonyb. Please forgive me for all the dirt you see on all the photos as I live on a dirt road and it has been dry around here. JD
Offline Bearcat
    • Automatic Garage Door Services
« Reply #12 on: September 29, 2018, 06:35:24 am »
HTH,
​JD​
I looks like you ground the inside and outside bottom face of the caliper bracket.
Offline Bearcat
« Reply #13 on: September 29, 2018, 06:36:46 am »
Would you happen to have a source for the machine shop that did your wheel ?
Offline K_C_M
« Reply #14 on: October 08, 2018, 12:34:59 pm »
Does anyone know what the equivalent bike in Europe is to the Vulcan Nomad, as I can’t find any brakes with a reference to this bike in any of the European forums or suppliers!  However, there is a VN1500 drifter with many different model numbers, but I can’t find which one is the same as the Nomad.
Or, can someone tell me the specifications for the front disc/rotor for the Vulcan Nomad year 99/04 is? This way I might be able to match something from one of the no-name suppliers.
Thanks.
GTR1000 1991 (From new)
GTR1000 1996 (Back from the dead!)
GTR1000 2006 (California import)
Honda CBf125
  • COG#: 13095
« Reply #15 on: October 08, 2018, 05:56:54 pm »
Thanks.
The Suzuki Marauder 1600 VZ1600 is the exact same as the Mean Streak bike built by Kawasaki for Suzuki.  Good luck.
« Reply #16 on: October 10, 2018, 03:12:24 am »
Try cutting it a third time... you know the old saying, 'third time's a charm'.
