Author Topic: Bafflectomy  (Read 1883 times)
Offline Slybones
  • COG#: 6953
Bafflectomy
« on: January 07, 2009, 05:44:00 pm »
Anyone in the local everett area with a 1" hole saw for doing the bafflectomy? Finally getting around to giving this a test drive.  2003 Concours, 46K  COG #6953  IBA 28004  http://mysite.verizon.net/slybones/Concours/connieMain.htm
2003 Concours, 121K
2005 GL1800ABS, 52K
COG #6953, IBA 28004
Offline Wizeguy
  • Closet Hooligan
  • COG#: 12487
Bafflectomy
« Reply #1 on: January 07, 2009, 06:21:00 pm »
Talk to Hill, I'm sure he'd let you use the same one we did mine with.    :eg:    Should only take, what, around an hour a side with that frickin thing?        Mike B / Gig Harbor, WA
Mike B / Seatac, Washington
1989 C10 "Gigi"
Former COG#6624
Offline Slybones
  • COG#: 6953
Bafflectomy
« Reply #2 on: January 07, 2009, 06:59:00 pm »
When did you do yours? Was it before the regional last year?   2003 Concours, 46K  COG #6953  IBA 28004  http://mysite.verizon.net/slybones/Concours/connieMain.htm
2003 Concours, 121K
2005 GL1800ABS, 52K
Offline Sahagan
Bafflectomy
« Reply #3 on: January 07, 2009, 07:57:00 pm »
Why not make your own surgical tool? I used a used horseshoe post for mine....anything 2 foot long, 1 inch or less in diameter, that you can hit with a hammer will do the job just fine. Rebar steel, 1/2 or 3/4 inch iron pipe (3/4 may be a tad too big on the outside diameter), etc.    In fact, it seems that you're less driving a hole through steel, than you are just popping off some kind of cap or cover.    And I do recommend the surgery....    Sahagan
Offline Wizeguy
  • Closet Hooligan
  • COG#: 12487
Bafflectomy
« Reply #4 on: January 09, 2009, 02:08:00 am »
Naw, did it at Chez Prior's place last October(?)  Or was it November?  Whenever it was.    Of course now I have to mess with the carbs...  I suppose that's what I get for screwing around with some Japanese engineer's hard work.  Mike B / Gig Harbor, WA
1989 C10 "Gigi"
Former COG#6624
Offline Intruder
  • All Weather Medium Attack!!!
Bafflectomy
« Reply #5 on: January 13, 2009, 07:15:00 pm »
Hey Mike I have a new hole saw! It only takes about a minute a side now. ;p     Fred you can drop by and use mine.     As far as the carbs go SISF has a nice carb kit!  :p      Jim #7353  Everett, WA    Current Bikes: '06 Concours "NTRUDR",'84 Honda VT-500 Ascot  Past Bikes: '02 Honda 919, '83 Honda XL200R, '81 Suzuki GS-750E, '69 BSA 441 Victor    WB7JH - ARRL Life Member  U.S. Navy Retired
Jim
AECS US Navy Retired
1984 Honda VT500 Ascot
Offline Slybones
  • COG#: 6953
Bafflectomy
« Reply #6 on: January 14, 2009, 03:07:00 am »
Jim, you done the carb kit yet? Mine is sitting here on the computer desk. At this point I am thinking of waiting for Colin to post a March tech session and will do it there for everyone to see.  2003 Concours, 46K  COG #6953  IBA 28004  http://mysite.verizon.net/slybones/Concours/connieMain.htm
2003 Concours, 121K
2005 GL1800ABS, 52K
