Author Topic: Banjo Bolt area.  (Read 435 times)
Offline Katsi
Banjo Bolt area.
« on: April 30, 2018, 03:10:53 pm »
On the left side of the bike just above the shift lever, their is a banjo bolt.  That bolt is attached to some sort of cover.  What is that because mine leaks from there.  Is it the clutch?
Re: Banjo Bolt area.
« Reply #1 on: April 30, 2018, 03:16:51 pm »
Clutch Slave Cylinder.
Offline Katsi
« Reply #2 on: April 30, 2018, 04:02:41 pm »
Easy fix or major PITA?
« Reply #3 on: April 30, 2018, 06:16:28 pm »
Remove bolt, install 2 new washers, reinstall, fill and flush clutch hydraulics, (clean up mess).
While your at it, I would remove the slave cylinder and clean the ID of it.
« Reply #4 on: April 30, 2018, 06:35:04 pm »
First I would wipe everything with a rag and brake cleaner, and stick a wrench on that bolt, and snug it... don't be a monster, just make sure its tight......
Then, if it stops leaking its fixed... and was easy...  :great:
Pulling everything off and cleaning and replacing seals, and such may not be needed...
If it isn't fixed, well, its a pull it off and rebuild while its off, just because your gonna have to bleed the sytem at that point anyways.. that the p.I.t.a. part..., even tho you are just needing copper washers replaced.
Lots of people turn a 20 second job, into a costly 4 hour pain, by getting the cart before the horse..
« Reply #5 on: April 30, 2018, 06:51:48 pm »
Good point. Try tightening first.
I assumed you had already done that?
« Reply #6 on: April 30, 2018, 07:09:50 pm »
Just for giggles, I'll add the torque spec.....  21 foot pounds...  22 is max...  3 Kg-m,   or 29 N-m.....
Ahhhh Ted.... :rotflmao: :rotflmao: :rotflmao: :rotflmao: :rotflmao: :rotflmao:
« Last Edit: April 30, 2018, 07:30:01 pm by MAN OF BLUES »
