Author Topic: C-10 Headlight Adjustment  (Read 674 times)
Offline CRocker
  • '02 C10 CDA # 416
« on: February 23, 2019, 11:54:21 pm »
So, I replaced the headlight bulb (a standard H-4) with a Pathfinder LED...which is much brighter...but, when I put a phillips head screwdriver into the adjuster and turn on the screwdriver handle...nothing happens.  I found a thread from 2013 that addresses this...but, it suggests removing the upper fairing...
Is there a more expedient way that's been discovered in the last five years...?
Thanks in advance...
Offline Rod
  • COG#: 11095
Re: C-10 Headlight Adjustment
« Reply #1 on: February 24, 2019, 02:14:59 pm »
 CRocker how do you like the Pathfinder LED,i need to replace my standard bulb also.Rod thank you
Offline CRocker
  • '02 C10 CDA # 416
« Reply #2 on: February 24, 2019, 03:05:56 pm »
Pathfinder bulb seems much brighter...but, I try not to ride after dark.  Did a lot to my C-10...replaced the 4 into 1 with stock exhaust (so I could have a center stand)...then there was the sealing washer...then there was a hose clamp...and, then a hose...sheesh!  Then there was the headlight reflector I replaced.  I think I’m going to try the broomstick method for adjusting the headlight...just took the bike for a shakedown run this morning...but, the bulb seems much brighter...
« Last Edit: February 24, 2019, 03:17:40 pm by CRocker, Reason: Headlight reflector... »
Offline Boomer
  • Wickford, UK
    • Boomers GTR Site
« Reply #3 on: February 24, 2019, 04:09:00 pm »
There are 2 adjusters. One for up/down, one for left/right. You need to check that the screwdriver is turning the adjuster. If you take the fairing inners off you can see the back if the adjusters.
George "Boomer" Garratt
Wickford, UK
CDA-007
« Reply #4 on: February 24, 2019, 04:43:17 pm »
2013 Kawasaki Concours 14
« Reply #5 on: February 24, 2019, 06:35:25 pm »
if you can find a picture of the "broomstick tool", which is a 1" long piece of wood, with 3 small finish nails in the end, snipped off, to make "prongs" that coincide with the 3 small holes, you will find it works far superior to any phillips screwdriver, because you don't have to contort to get the driver in thru the "guider" in the bracket...
Guy B. Young made the tool, and may have a picture on his site of it..
I made one when he showed it to me, and used to have it in my onboard tool box.. but somewhere along the line I lost it.
bummer...
Offline connieklr
  • COG#: 1608
« Reply #6 on: February 24, 2019, 08:29:10 pm »
________________
Guy Young
COG #1608
COG Life Member
Semi-Civilian
GB Young Services, LLC
« Reply #7 on: February 24, 2019, 08:55:44 pm »
 :great: :great: :great: :great: :great: :great: :great:
dat be da one.... :great:
thanks  :beerchug:
Offline CRocker
  • '02 C10 CDA # 416
« Reply #8 on: February 24, 2019, 09:11:53 pm »
Yep...that's like the one I had in my garage in Colorado for years...don't know where it went... :(
Offline connieklr
  • COG#: 1608
« Reply #9 on: February 24, 2019, 09:23:58 pm »
"Our" cartoon-meister, Harry Martin made a system so he could adjust it from the bike's dash. I had his entire piece in one of my columns.
________________
Guy Young
COG #1608
COG Life Member
Semi-Civilian
« Reply #10 on: February 24, 2019, 11:06:53 pm »
WOW....that's amazing  :-\ :-\ :-\ :-\
so now we can say HARRY deigned the adjuster, that KAW stole his idea from, which is EXACTLY what they put on the C14... and who said all Harry does is draw cartoons...
(Ted did... but consider the source  ::) :rotflmao: )
Hats off to Harry.... :great: :great: :great: :great: :great:
thanks for sharing that, really cool you kept that photo... :great:
Offline The Doctor
  • COG#: 12886
« Reply #11 on: February 25, 2019, 05:15:11 am »
Darn... it didn't come with the bike, just the broomstick tool.
It all started on a 250...
Offline connieklr
  • COG#: 1608
« Reply #12 on: February 25, 2019, 10:28:14 am »
Yup. Up and down adjuster is on the lower left as viewed from the rear; left and right is upper right.
________________
Guy Young
COG #1608
COG Life Member
Semi-Civilian
Offline CRocker
  • '02 C10 CDA # 416
« Reply #13 on: February 25, 2019, 02:14:55 pm »
Yep...that's the one I was trying...lower left...oh well...onwards to the broomstick method...
