Author Topic: Brake calliper assembly lube  (Read 785 times)
Offline Bob H
  • COG#: 788
« on: December 22, 2017, 10:43:47 pm »
The question of how to lube brake pistons and seals when reassembling them seems to come up periodically.  Using brake fluid works, but leaves a bit of brake fluid on the exterior parts.  Not really good considering the affinity of brake fluid for moisture.
While wandering around the net looking for a brake assembly lubericant, I found this stuff:
http://redrubbergrease.com/
https://www.amazon.com/gp/product/B01L63YQ4U/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
 It's called Red Rubber Grease, made by Castrol.  Looks like it might be a good solution, but I don't have any knowledge of how well it actually works.
Has anyone used this stuff?
 '88 one owner:
Offline seagiant1
  • COG#: 11323
Re: Brake calliper assembly lube
« Reply #1 on: December 22, 2017, 11:07:05 pm »
Hi,
      The ONLY thing I would use Brake/Caliper grease on....
Would be the slider pins on some AUTO brake systems and the contact points on the,  Brake Shoes/Calipers!
As far as anything around the boot piston covers....Brake fluid only!
ANY amount of a petrol based fluid in the brake system and you have big problems!
I use CRC Synthetic Brake Caliper Grease!
My opinion! ;D
« Reply #2 on: December 22, 2017, 11:14:10 pm »
I bought some high dollar rebuild kits with stainless steel pistons and they had a little container of red grease that they advised using on the seals.  I looked at the link you posted.  Looks like what you need.  Never heard of the stuff before buying kits from Brake Crafters.
« Last Edit: December 22, 2017, 11:20:35 pm by Bud »
Offline jacksdad
« Reply #3 on: December 23, 2017, 02:26:20 pm »
I use RRG on car and bike brake sliders, piston dust seals etc. and Ceratec brake grease on the backs of pads, metal to metal sliders.
There is a guy on ebay UK that sells 2" round tins of greases, RRG, zinc and aluminium stuff for stainless steel, I bought a few which cover every combo I'll see
