Author Topic: Brake line  (Read 1036 times)
Offline Tjnoma99
  • COG#: 12686
Brake line
« on: September 23, 2017, 11:21:42 pm »
I added 1 1/4 risers to my bike. The top brake line is taught but still has a little play. Should I replace it with a longer line? Or can I unbolt the t junction and create a bracket to move it up a bit?
Offline Bob_C_CT
Re: Brake line
« Reply #1 on: September 24, 2017, 12:03:08 pm »
If the brake line is oem I would think about replacing it with a braided one. Temporarily I guess you could try getting more slack by moving the splitter up a little but make sure you have enough slack both at the bars and the wheel for full movement.
Offline Tjnoma99
  • COG#: 12686
Re: Brake line
« Reply #2 on: September 25, 2017, 01:13:14 am »
I have the fairing off and it looks like the line has enough room to move when the bars are turned. I did find a brake line from eBay that is supposed to be from the junction to the caliper. I figured I can use that until I can get a set of braided lines!
  • --2006 Concours--
Re: Brake line
« Reply #3 on: September 25, 2017, 01:22:39 am »
Remember the suspension travels down, as well as up... ** Carefully** Jack the front up... see if you have 'slack' then.
I needed new lines with the risers, and I had braided lines  :(  These things happen.
Performance -- Rear: C14 Shock - Front: Sonic 1.1 w/emulators - SISF Jet Mod & Ex Cam Sprocket - Tokico front brakes
Offline Bob_C_CT
Re: Brake line
« Reply #4 on: September 25, 2017, 10:02:56 am »
Very good point McFly on the suspension extension and retraction.
Offline mnbikeguy
Re: Brake line
« Reply #5 on: September 25, 2017, 04:13:57 pm »
Up/down will not affect the upper BRAKE line as it is a fixed length between the master cylinder and the junction because the junction is bolted to the triple tree. Movement only occurs below the junction on the BRAKE line. Left/right movement will affect the CLUTCH line though.
« Last Edit: September 25, 2017, 09:47:14 pm by mnbikeguy »
Offline Tjnoma99
  • COG#: 12686
Re: Brake line
« Reply #6 on: September 25, 2017, 04:36:41 pm »
The clutch line looks fine to me.
Re: Brake line
« Reply #7 on: September 25, 2017, 04:49:39 pm »
You want to get rid of the T- junction anyway and replace those lines with a 2 line extended kit.
Murphs kits is your friend in this situation.
2000 Red C10 1052 kit
Offline mnbikeguy
Re: Brake line
« Reply #8 on: September 25, 2017, 09:48:22 pm »
This
Offline Jim Snyder
  • The Connie Rocks !!!
  • COG#: 7055
Re: Brake line
« Reply #9 on: September 25, 2017, 10:44:31 pm »
T,
 You may need to get longer brake hoses but all of the other cables and lines can be re-routed to give you more slack. You can re-route the throttle cables on the right side of the frame and gain a few inches there. The clutch hose can also be re-positioned for a little extra slack. The one cable that may be tight will be the choke enrichener cable. Murph has the extended versions of those as well.
Re: Brake line
« Reply #10 on: September 26, 2017, 05:09:28 am »
Enrichener cable is easily rerouted along the backbone of the frame, to provide additional usable length, I did this on both my C10's when I went to tubular bar mounts...
