Author Topic: Broken right foot bracket  (Read 1272 times)
Offline Mikenasty89
« on: July 26, 2017, 07:51:17 pm »
Basicly i need help replacing the right foot bracket (not just the foot peg)  sadly I dropped my connie being new to riding and the peg bracket took all the weight... as I struggled to prevent the fairing from touching cement.....  might have been already damaged before its day 3 of owning  it and the previous owner admitted to a full drop. But I was so in love with the bike i figured (father in law is a mechanic with a shop but im embarrassed to ask, he rides too) that i could fix anything there. Anyway back to the point 98 connie, right front peg. Any assistance or links to something would be super helpful. Thank you! -mike
Re: Broken right foot bracket
« Reply #1 on: July 26, 2017, 09:27:32 pm »
  Pretty hard to find as most of us have wasted one side or the other. :'(
  Damn, forgot about MURPHS"!!!  He has them and ships FAST.  :great:     https://www.murphskits.com/product_info.php?cPath=1_107&products_id=184
       Might try BikeBandit.  They show them but may no have them. About $ 63.00
   Welcome to the COG Forum!! :great:  Glad you like the C10!! I like mine for 23 yrs!!
   Might try this member. has a lot of used STUFF.
 http://forum.cog-online.org/profile/?u=40419
« Last Edit: July 27, 2017, 01:18:20 pm by Mettler1 »
« Reply #2 on: July 26, 2017, 10:23:17 pm »
Don't forget The Wizard!  COG's own most favorite used parts guy!  Get in touch with him and it will be out the door and on the way in a hurry.  Calling The Wizard!!   :)
Offline MichiGlenn
  • "Wherever you are, be all there" Jim Elliot
  • COG#: 10892
« Reply #3 on: July 26, 2017, 10:44:27 pm »
Murphskits.com stocks them as well as other OEM and aftermarket parts for our Connies. He's a COGger and gives a fair price and good service
2001 C-10
1977 Honda CB750K Sold
1978 Honda CB750K Long Gone
1972 Honda CL175 Ancient History
Heald Super Tryke 8hp, Wards T555 Trike
Offline RWulf
  • COG#: 7122
« Reply #4 on: July 26, 2017, 11:09:41 pm »
 When you get the part you need take a chose look at how the
peg folds up. You will notice the peg hits the bracket (the part bolted to
the bike) and will not fold any further. If you have your father in law
grind the peg so the radius is completed the peg will fold up further
and you may not brake it next time you drop it. Do both sides.
Don't tell father in law where you got this idea, he will think you are
smarter and more observant.
Online Cal
  • COG#: 12008
« Reply #5 on: July 27, 2017, 11:01:34 am »
and while you are doing the one side - take apart the opposite side and check for cracks!  scary to think you might stand on a cracked peg assembly while going over a rough spot!
point is I did find a cracked peg mount!  no idea how long it had been that way.
Cal
Offline Derick
    • BeginnerBikers.org
« Reply #6 on: July 27, 2017, 03:02:03 pm »
Cal
That's no bueno.....reminds me when I had a girl on the back of my 86. A few days later I was doing a pre-trip inspection and found that one of the passenger foot pegs had like a fraction of one bolt thread in, and the other had fallen out..  :o
Current Bikes:
« Reply #7 on: July 27, 2017, 08:14:09 pm »
Cal
Whoopsie
Offline Mikenasty89
« Reply #8 on: July 27, 2017, 09:22:43 pm »
All good ideas thanks, yeah i got a new bracket off the ebay for 56 bucks should be here soon..... just gotta figure out what i need to remove . Picture of the damage attached...
Offline Mikenasty89
« Reply #9 on: July 27, 2017, 09:24:22 pm »
Looks like a pain in the butt compared to the other side thanks to my break.....
« Reply #10 on: July 27, 2017, 10:45:45 pm »
Clean up and examine that E-bay bracket very carefully... good luck!
« Reply #11 on: July 28, 2017, 12:10:35 am »
I've never heard of the bracket breaking and not the footpeg too.
Clean up and examine your footpeg very carefully... good luck!
Offline Mikenasty89
« Reply #12 on: July 29, 2017, 11:40:13 am »
Got my new bracket, not a mechanic in any sense of word but i do pick up things quickly. I know what 95% of this means anything i dont ill google or ask you fine people but does this sound correct? Also dunno if the bracket changed too much but mine bikes year is 98 his is 2000.
"Reply #2
by
Roadhound
 on 23 May, 2011 17:10
It's not as bad as it looks. Remove the two bolts fastening your rear brake master cylinder to the footpeg bracket Remove the bottom bolt located under the brake lever, remove the upper bolt located between but above the rear brake master cylinder. The footpeg bracket can be removed from the bike at this time. You can now pull the clevis pin and remove the master cylinder clevis pin. If you need to separate the 2 pieces which make up the bracket assembly, remove the 2 bolts on the back side of the footpeg bracket."
Offline Mikenasty89
« Reply #13 on: July 29, 2017, 11:44:54 am »
Cuz i feel seriously crippled out there trying to learn with only front brake at the ready and a back brake a look away from the road to find my footing. So minus the shameful ride home the driveway loop i made the next day to keep my cofidence shes been sitting there waiting for a new bracket. :(
« Reply #14 on: July 29, 2017, 01:45:21 pm »
Mike, you can remove the lower front bolt from the bracket and replace it with a longer bolt.
That longer bolt will work as a temporary foot peg....
Offline Mikenasty89
« Reply #15 on: July 29, 2017, 02:28:49 pm »
Ive got all the parts i need just need the right tool and to know if the instructions above are correct. Any pictures, suggestions and tips are appeciated. Good idea about the bolt.....i was trying to think of a quick fix, so simple yet effective. Thanks ill keep that in mind just in case.....
« Reply #16 on: July 29, 2017, 02:46:08 pm »
When you do the install, grind/clearance the footpeg so that it can pivot all the way up.
In stock form it binds. Grind away the material where it binds.
The grinding will make it less likely to break if you drop it again.
Offline Mikenasty89
« Reply #17 on: July 29, 2017, 06:49:26 pm »
Def. On a to do list get my pedals on the grinder.
Online The Wizard
  • COG#: 11328
« Reply #18 on: July 29, 2017, 08:02:31 pm »
Mike,I am in possession of a few Clymer maintenance books($17+postage,media is cheap)or I have the Kawasaki service Manual.A few I believe($22.50+media postage).       The Wizard
Offline Mikenasty89
« Reply #19 on: July 30, 2017, 12:17:43 am »
Ill send you a pm
Offline Mikenasty89
« Reply #20 on: August 08, 2017, 10:28:14 pm »
There finally fixed my connie and shes ready to ride.
« Reply #21 on: August 09, 2017, 01:19:40 am »
So you installed a new mount..ntheat works, what's that peanut butter slathered on your muffler...?
Just joking.
Pull both pedals and grind the mounts so they will fold up during futur "bike naps". ... do it now, don't wait... its a necessary pre emptive protection, and you'll never buy another mount.. well... hopefully.... :great:
Offline Jim
  • Jim
« Reply #22 on: August 09, 2017, 10:27:15 am »
Here's the link to the foot peg modification:
http://www.delp.net/Concours/Tech/Footpeg_Mod/index.htm
Offline Jorge
  • COG#: 9297
« Reply #23 on: August 09, 2017, 09:18:32 pm »
Well done! and welcome.
