Author Topic: C-10 Antler ?  (Read 260 times)
Offline frenche
  • COG#: 12332
C-10 Antler ?
« on: September 18, 2018, 07:43:26 pm »
'99 C-10 runs great
'05 C-10 in pieces
Broken left antler on '99.
Replaced with left antler from '05.
'99 hardcase did not want to fit.
Are there differences that would keep this from working?
Thanks,
frenche
« Last Edit: September 19, 2018, 01:10:44 am by frenche »
Offline connieklr
  • COG#: 1608
Re: C-10 Antler ?
« Reply #1 on: September 18, 2018, 08:41:27 pm »
Same part numbers from '86 through the end of production, so they should work.
________________
Guy Young
COG #1608
COG Life Member
Semi-Civilian
GB Young Services, LLC
Offline CRocker
  • '02 C10 CDA # 416
Re: C-10 Antler ?
« Reply #2 on: September 18, 2018, 09:04:49 pm »
It works...it’s just pilot error...I deal with the same thing...and, it seems like on a regular basis...can’t get the antler rail into the groove on the bag...I’m sure there is a specified procedure...I just futz with it until it works...I’m sure somebody will chime in and help us both... :truce:
Offline Pbfoot
  • COG#: 10807
Re: C-10 Antler ?
« Reply #3 on: September 19, 2018, 11:21:34 am »
The angle that you start the bag onto the antler is critical. I struggled through the first few times until muscle memory took over and they go on every time now.
Offline Stasch
  • COG#: 6830
Re: C-10 Antler ?
« Reply #4 on: September 19, 2018, 03:38:36 pm »
I install / remove the saddlebags all the time.
I have found that in addition to the slight angle Pbfoot uses:
- First have the lower latch in the open position
- with Pbfoot's angle, start with the bag about a half inch off towards the rear of the bike
- engage the antler tabs onto the antler rail
- slide the bag forward to align the lower latch with antler latch mount
- pivot the angle down to where the lower clasp will grab the antler
- close the lower latch onto the antler
- DONE
Works like a charm for me - YMMV
