Author Topic: C 10 valve adjust -- do-able without socket wrenches?  (Read 622 times)
Offline Bucky
  • COG#: 11949
« on: October 14, 2017, 05:09:04 pm »
I'm about to delve into a C 10 valve adjustment. Just discovered my ratchets are at work, an hour and 15 round trip - a trip I've made waaaaay too many times, so,
Can I get it done without ratchets? Using just combination wrenches?
Thanks.
Antique Machinery Junkie
Offline GeorgeRYoung
Re: C 10 valve adjust -- do-able without socket wrenches?
« Reply #1 on: October 14, 2017, 05:16:31 pm »
I think the most critical thing is getting out the spark plugs. Maybe if your Concours toolkit contains a spark plug wrench.
Offline Bucky
  • COG#: 11949
« Reply #2 on: October 14, 2017, 05:18:12 pm »
Answered my own question -- yes I need the sockets for torque time.
As "they" say - Oh well...
Offline Bucky
  • COG#: 11949
« Reply #3 on: October 14, 2017, 05:19:45 pm »
True - the plugs. Good point.
I'm kinda torque wrench friendly when it comes to aluminum, so yeah, a trip to work it is.
I forgot to stop at the cuss word store after I bought the RTV, so a head heli coil campaign is not possible today.  :)
Offline Outback Jon
  • COG#: 9506
« Reply #4 on: October 14, 2017, 10:59:13 pm »
Just remember that the torque value in the shop manuals for the valve nuts is wrong.  (I don't recall the right value, but it is supposed to be in/lbs, not ft/lbs like listed.)
Offline Jim
  • Jim
« Reply #5 on: October 16, 2017, 11:26:34 am »
18 ft/lbs is a bit heavy for those nuts.  I've been using 13 ft/lbs (156 in/lbs) with good results.  Interestingly enough, my '84 Honda Sabre had an almost identical valve setup and it's torque value was 17 ft/lbs (I believe, could have been 18 ft/lbs, also).  They even sold a special, 1 foot long, 10mm wrench for tightening them back up.
Offline Bucky
  • COG#: 11949
« Reply #6 on: October 16, 2017, 06:10:28 pm »
Thanks. I did those freehand.  I did make an audible "ka-tink" sound while I was doing it though.  :)
I did behave myself with the spark plugs and the valve cover bolts though. Turns out the valve cover bolts correct torque is pretty much snug until they stop -- ka tink.
« Last Edit: October 16, 2017, 06:25:57 pm by Bucky »
