Author Topic: C10 speedometer gear position  (Read 252 times)
Offline bvfa65
« on: June 23, 2018, 07:54:33 pm »
I had tires on my '87 Concours replaced but not by a Kawasaki dealer. When they reinstalled the front wheel, they didnt get the speedometer gear in the right position. A few miles later the cable broke. They are going to replace the cable and reposition the gear. I have documentation on aligning it, but I can see a small chip on the gear housing, I'm thinking it might be the alignment tab? Would someone be able to please post a side view picture showing the angle that the gear housing should be in to properly attach the cable. Thank you.
Re: C10 speedometer gear position
« Reply #1 on: June 23, 2018, 08:21:07 pm »
I hate when that happens... but a lot of people do the same thing, make sure they replace that drive hub, because it's now all chewed to heck, and will be an issue, and probably the grease seal too...
reciever hub p/n 41064-1006
grease seal p/n 92049-1057
when they are jambed up, it smooshes the ears on the hub, and also then the seal gets chewed up inside....
see the pictures...
