Author Topic: C10 Water pump oil seal  (Read 431 times)
Offline K_C_M
« on: October 16, 2018, 03:55:17 pm »
I just pulled the water pump out of my GTR1000 because it’s leaking oil (and 24 year old!).  I got a new oil seal from Kawasaki (P/N 92049-1416) but when I got the original oil seal out of the pump its approximately 3mm smaller than the new part (25mm vs 28mm). Obviously I can’t get this to fit!
Has anyone else had the same problem? Is this just a mistake in packaging by Kawasaki, or am I missing something obvious?
Re: C10 Water pump oil seal
« Reply #1 on: October 16, 2018, 08:36:47 pm »
Well if it's a packaging error, they made that mistake more than once.  I have a new seal of that part # laying around and it measured 28mm.  I never used the seal since when I got the pump out, it had more problems than just the seal.  I bought a new pump from Murph.
« Reply #2 on: October 16, 2018, 09:59:38 pm »
Is this a US bike, or a Euro (GTR mentioned) bike?
I've replaced dozens of these seals, using the 92049-1416, and never had this pop up...
is it possible the waterpump was replaced with one from a different Kaw Model, like a ZX900/ZX1000 ninja, or something?
I don't think that would even matter tho... I recall some Euro versions had a pump, that could be dis assembled by pressing out the shaft, which the US models could not be repaired in that manner ( this was brought up during a lengthy discussion about the ceramic water sealing section, not the oil seal)..
I don't know what you have, but the 92049-1416 has been the working part here for decades...
Offline K_C_M
« Reply #3 on: October 17, 2018, 11:24:25 am »
I’m waiting to see what the Kawasaki dealer says today, but I have 2 of these bikes and a spare engine. I’ve now taken out 3 pumps and they are all the same.
These are all European bikes (UK-spec), but so far everything in the cooling system is the same as described in the Clymer & Kawasaki workshop manuals and of course from the many threads on COG forums.
« Reply #4 on: October 17, 2018, 09:28:20 pm »
this is exactly what I suspected, as back in time, the person that posted ( an Italian fellow, and it required much translation to print it) about a w/p 're-build' did it on a Euro GTR bike; and the pump he was building did have some differences that appeared. Just curious, can you look up the part number on a euro Kaw Microfiche, and post the water pump assembly number?
The American/North America part number is
49044-1083   PUMP-WATER  (this part replaced p/n 49044-1058)
that would help us out, I know the older euro models actually had a coolant line that ran up to the carb bodies, to circulate warmed coolant to prevent "icing', primarily on the German models. never had the chance to do ant service to a Euro bike, so I'm sure there are other small differences. Might want to pose this question to some of the guys on the GTR forum, as they may have provided a seal replacement work around as we did.
http://eu.zggtr.org/
also, our Australian pals my have input...
http://www.gtr-aus.com/
please report back, we would be glad to add it to our database.
EDIT TO ADD:
I went to numerous suppliers sites, in Europe (UK, FR, ) and found the exact same part numbers I have noted for the water pump, and also that seal... so I am at a loss of what is in place, you may end up purchasing a complete water pump, if so, please report back the seal size in the new pump, compared to the defective one,
best of luck, sorry for the lack of help here,
« Last Edit: October 17, 2018, 10:23:11 pm by MAN OF BLUES »
Offline Captsparrow
« Reply #5 on: October 17, 2018, 10:43:29 pm »
G'Day Guys, This is from Brissy GTR from GTR-AUS of which I am a member:
brissyGTR
Posts    2,680
2IC
11:31 PM - Nov 29, 2013 #8
The water pump is on and clocked up 150km today. Checked the water level about 4 times today and all looking good. No puddles under the bike either. The fan didn't switch on as the temp guage rose above 1/2 way. A fiddle of the wires on the temp switch and it started. Something to watch in the future. I was paying more attention to the temp guage today than I would normally. Here are the parts I used (part numbers and prices) to rebuild the water pump.
Kawasaki parts;
920551271   Ring-O, water pump   $13.13
920551424   Ring-O, 33.2x2.4   $7.56
920491416   Seal-oil, water pump   $11.67
CBC Bearings parts;
EH790J08DBQ   Seal assy, Mechanical general   $15.40
6001LLU   Bearing, Ball, SRDG Metric (2x$7.70)   $15.40
BS120   O-Rings   $0.33
When I fitted the bearings they were popped into the fridge for about 10 minutes (still inside their plastic bags) and the pump housing in the sun. Bearings fell into position. A 21mm spark plug spanner is the same size as the bearings and seal for keeping them pressed into place.
Might help a little further in the issue. Cheers,
« Reply #6 on: October 17, 2018, 11:26:18 pm »
brissyGTR
Posts    2,680
2IC
Kawasaki parts;
CBC Bearings parts;
BS120   O-Rings   $0.33
Ta, Bonzer mate! the seal in question seems to be universally used...
Crack a tinnie for your efforts,
Hooroo and cheers,
 :beerchug: :beerchug:
we sincerely miss old Dave'O still..    :'(    .
 :beerchug:
Offline Captsparrow
« Reply #7 on: October 18, 2018, 12:23:15 am »
No worries. Absolute tragic event. Never met the bloke but what I have read about him a really nice fella.
Offline K_C_M
« Reply #8 on: October 22, 2018, 03:58:23 pm »
I checked all the microfiche web sites in the UK and other countries, always selecting the UK variations where possible and they all showed p/n92049-1416 as being the correct oil seal part.  I spoke to a couple of dealers direct and they also thought that it should be the correct part.  However, I have 3 water pumps from 3 different engines (1991 A5, 1994 A9 and 1995 A9) all using a smaller oil seal.
I then called a seal and bearing specialist who advised to look closely at the seals I have got and on 2 of them a serial no. ‘S12257L’ was embossed on the inner face.  He identified that this was in fact 12mm inner diameter, 25mm outer diameter and 7mm thick.  I ordered the seal and it was a perfect match and good fit.  Construction of the seal was also identical to the original item.
Happy days, now I just need to get the rest of the cooling system back together.
« Reply #9 on: October 22, 2018, 06:17:27 pm »
 :great: :great: :great:
congrats, glad you got hooked up...
as for the seals, this was the FIRST time this ever came up that I know of in 15 years of Concours ownership, and I was the Tech Editor for a while, so I'm very surprised.
Now I have to go and check the seals I have, to see what they are, and if they are marked in a similar manner, both new ones, and the ones I pulled during replacements.
that number you supplied definatly does describe the size, and I never disputed it, just never had it come up..
great job, thanks for your info also... :great: :great: :great: :great: :great: :great: :beerchug: :beerchug:
