Author Topic: Capacitor Discharge Ignition ?  (Read 3260 times)
Offline MadMax
Re: Capacitor Discharge Ignition ?
« Reply #25 on: January 13, 2016, 06:47:37 am »
Hi Bob, The picture was very helpful. So the output transistor are 2SD1071  Specifics are: Fuji Transistor TO-220AB 450V 6A 40W. They are not even designed for ignition systems, but for high voltage audio amps. They seem to work OK though.
Now having looked at a few data sheets, it looks like the most powerful Mosfet in the same package (T0220) is the 20N50 range.  500v - 20A - 0.21Ω. That should cope with two stick coils in parallel and only 0.84v (at 4A) drop across the transistor and less internal heat.
If you just want to repair a igniter then a IRF840 (500v-8A) should be a good alternative. This is used in many ignition systems.
I wish I was at home now, I would have a go myself. But I’m on holiday until the weather warms up in the UK.  I will give it a go when I get back.
.I’ll add this to the Jobs list. I’ll also give a CDI system a go. Nothing to loose but time.
Offline Zorlac
  • COG#: 6962
« Reply #26 on: January 13, 2016, 11:26:00 am »
FWIW, power FETs may or may not be "drop in replacements" for bipolar transistors depending on the circuit.
The 2SD1071 is a bipolar darlington transistor.
« Last Edit: January 13, 2016, 01:56:21 pm by Zorlac »
COG #6962
Offline JDM
  • COG#: 8877
« Reply #27 on: January 13, 2016, 01:01:48 pm »
Zorlac, good to see you are still around and kicking. Are you still running the 12v solenoid valve?
Happy New Year
Offline Zorlac
  • COG#: 6962
« Reply #28 on: January 13, 2016, 01:57:40 pm »
Happy New Year
Yep, same to you!
COG #6962
