Author Topic: carb boots  (Read 614 times)
Offline DKAW
  • COG#: 9299
carb boots
« on: September 02, 2017, 08:22:56 pm »
Does anyone know the difference between the 2and4 cylinder boot and the 1and3 cylinder boot? I didn't mark them after removing them from the airbox.
2003 Concours.
Re: carb boots
« Reply #1 on: September 02, 2017, 08:32:36 pm »
The flats on the airbox end face each other on 1&2 and 3&4..
When inserted into the airbox holes, the longer snorkle end goes at the top, and the close snorkle end is the bottom...
So, to splain it easier... set them all on the bent snorkle ends, with the carb ends facing upward, and match the flats on the body of the boot, where it seals that grroved ring on the box... that should be easiest to understand.
#1 & #3 are the same,   and #2 & #4 are the same, really doesn't make any difference which goes where, if that is your question...
« Last Edit: September 02, 2017, 08:49:14 pm by MAN OF BLUES »
Offline DKAW
  • COG#: 9299
Re: carb boots
« Reply #2 on: September 03, 2017, 01:55:55 am »
Thanks for excellent info. :beerchug:
2003 Concours.
Offline Derick
    • BeginnerBikers.org
  • COG#: 11628
Re: carb boots
« Reply #3 on: September 03, 2017, 02:15:01 am »
The part numbers are on the boots;
14073-1224, for cylinders 1 and 3
14073-1225, for cylinders 2 and 4
Current Bikes:
Re: carb boots
« Reply #4 on: September 03, 2017, 05:44:11 am »
I have an 2 old sets, '86&'88 and one new set in bags, none of mine had/have the numbers moulded in... the new set in bags was purchased in '05, and does have part number on the bag tho..
When I pulled the first set outta the bags, and went to install them, I did in all truth have an "oh crap... which is which " moment... but that passed quickly as I knew what they looked like when installed... :rotflmao: :rotflmao: :rotflmao: :rotflmao: :rotflmao:
Offline goatmar
  • COG#: 7957
Re: carb boots
« Reply #5 on: September 06, 2017, 04:00:02 pm »
What air box?  :-[
Re: carb boots
« Reply #6 on: September 06, 2017, 07:03:17 pm »
What air box?  :-[
said the man with the slow bike  :pokestick:  Steve
Re: carb boots
« Reply #7 on: September 06, 2017, 07:39:43 pm »
     More noise = Mo power!! :motonoises:  It is a well established FACT!!! Everybody knows that.
Offline Stasch
  • COG#: 6830
Re: carb boots
« Reply #8 on: September 13, 2017, 10:57:59 am »
With the added benefit of saving lives.   :)
