Author Topic: Carb Jetting question(s)  (Read 457 times)
Offline Bearcat
    • Automatic Garage Door Services
« on: January 30, 2018, 08:10:41 pm »
When Kawasaki built the C10, did they jet the carburetors different for various altitudes ?
For example I live 2000 feet above sea level. I figure my 2006 C10 runs rich at my location.
If rode the C10 to the beach at sea level, wouldn't it run leaner or possible better ?
Offline SteveJ.
  • COG#: 5603
Re: Carb Jetting question(s)
« Reply #1 on: January 30, 2018, 08:42:12 pm »
The c-10 came from the factory with fat jetting.
Go here for more info: https://sites.google.com/site/shoodabenengineering/intake-and-exhaust
Tick Tock, baby (Ironbuttal)
« Reply #2 on: January 30, 2018, 08:52:42 pm »
  What SteveJ said!!
    Sisf did my carbs and now they are spot on!! :)  I tried cleaning and adjusting the carbs but never got them any better. Steve's carb service also includes overflow tubes that helps prevent "HYDROLOCK". Which can ruin your engine!! :'(
  It was the best investment I ever made to my C10!!
« Reply #3 on: January 30, 2018, 10:57:10 pm »
Bearcat, Unless the local dealer made changes, Kawasaki did not jet for different altitudes.
Your correct; It will run better at lower altitudes.
I'm a flatlander, live in Houston.
Trailered it to Colorado and went for a ride after I arrived.
The loss of power was immediately noticed!!
The reverse would be true if you trailered down out of the mountains.
If you ride down, the power changes gradually as you travel, so, it is less likely you will notice it...
« Last Edit: January 31, 2018, 02:32:21 pm by connie_rider »
Offline Bearcat
« Reply #4 on: January 31, 2018, 04:21:17 am »
Thank you everyone for the feedback and advice.
