Author Topic: clock shuts off and resets with key  (Read 1122 times)
Offline Mike Pieski_WA
« on: April 04, 2012, 10:37:49 pm »
So my clock resets back to 1:00 when I turn the key off. This just happened recently as I took the bike apart to change the dash bulbs. Any suggestions?
Offline Outback Jon
  • COG#: 9506
Re: clock shuts off and resets with key
« Reply #1 on: April 05, 2012, 12:26:05 am »
Accessory fuse.  The one that is mounted on top of the J-box.
But you might want to find out what caused it to blow.
« Reply #2 on: April 05, 2012, 12:41:46 am »
Yep, that's it. I'll continue to monitor it but it must have happened when I was changing bulbs.
Offline S Smith
  • Northeast Area Director
  • COG#: 3184
« Reply #3 on: April 05, 2012, 01:42:15 am »
Hey Jon... nice job on the quick diagnosis.  A dealer or other tech would have charged much more than the cost of a COG membership to fix that.  Kinda goes to show the wonders of COG.
| Steve Smith | COG #3184 |
BECOME A COG MEMBER
Offline Outback Jon
  • COG#: 9506
« Reply #4 on: April 05, 2012, 12:44:25 pm »
WARNING!  The preceding message has been  brought to you by an unpaid, underappreciated, COG Area Director.  WARNING!
 :nananana:
(But thanks, Steve.  This is one of those ridiculously easy ones that pops up from time to time.)
« Last Edit: April 05, 2012, 12:45:58 pm by Outback Jon »
« Reply #5 on: April 05, 2012, 04:41:13 pm »
I think that fuse also does the radiator fan motor so if it blows again or even if it does not check the blower fan operation.
Offline Bob_C_CT
« Reply #6 on: June 17, 2019, 11:30:06 am »
Reviving an old post.
Yesterday I replaced a rear turn signal bulb. It went out on a ride and I got the fast blinking turn signal indicator Replaced bulb all fine and good.
Today I noticed when I started the bike the clock was at 1:00, with bike running I set it to correct time. Didn't turn the bike off and on the road it went back to 1:00.
Will check fuses but the going back to 1:00 while running sounds weird.
Southern Connecticut.
Offline Bob_C_CT
« Reply #7 on: June 17, 2019, 04:40:41 pm »
All fuses checked good. The clock is at the right time, 4 hours after I shut the bike down, so I'm thinking gremlins.
So weird that it coincided with the rear turn signal bulb replacement.
