Author Topic: Disconnecting JBox from connectors  (Read 667 times)
Offline Red Eagle
« on: January 30, 2018, 02:43:32 am »
 :017:
1986 Concours; Jbox needs to be disconnected from wiring connectors; side panel off; fuses removed; plastic connectors have "latching pins" that snap into Jbox body. Do you depress latching pins? Lift up? Connectors seem to "snap" in when seated. I seem to remember removing the connectors before, but don't remember now what i did!
I'd sure appreciate COGs help before I try to send this to Larry for a rebuild.
Thanks,
Bob Young
COG #5753
Bob Young   COG #5753 C-10 A-1 CDA#307
Offline connieklr
  • COG#: 1608
Re: Disconnecting JBox from connectors
« Reply #1 on: January 30, 2018, 12:35:31 pm »
:017:
Thanks,
Bob Young
COG #5753
Squeeze hard on them to disengage their "hooks."
Sometimes it helps to push them into the box receptacle as far as possible before squeezing, but keep steady pressure on them as you retract them out of the box. Wiggling them side-to-side sometimes helps too.
« Last Edit: January 30, 2018, 01:58:10 pm by connieklr »
________________
Guy Young
COG #1608
COG Life Member
Semi-Civilian
GB Young Services, LLC
Offline RWulf
  • COG#: 7122
« Reply #2 on: January 30, 2018, 02:39:50 pm »
Ya they can be a pain in the butt. I sometimes have to use a
large blade screwdriver to pry them appart. Also WD-40 helps
some, downside it makes everything hard to hold onto.
Offline Red Eagle
« Reply #3 on: January 30, 2018, 02:55:09 pm »
 :great:
Guy:
Thanks for the pictures. That's exactly the info I was looking for. I'll just have to try that method. I figured there was a "latch" point some where in there and the manuals don't reference that at all.
RWolf:
 I thought about WD-40, but also thought about how difficult and slippery the connectors would be. But, thanks anyhow.
I just knew some one here would have answer.
Bob Young
COG #5753
Offline Nosmo
« Reply #4 on: January 31, 2018, 12:46:22 am »
Every time I have to fool with mine, I mean to cut off the latches but haven't yet, maybe next time.
Why on earth do we need latches on connectors that require 150 pounds of force to pull them apart?????????  >:(
2003 Connie    2007 Wee-Strom
Offline Red Eagle
« Reply #5 on: January 31, 2018, 03:05:16 pm »
Nosomo:
Maybe that's my problem......I don't think I have 150 lbs. of force in me!  At 79, that may have been spent in my youth or NOT!
But thanks for the input. It explains that I may have to work a little harder at it than I did. I sure didn't want to screw some thing up by "getting a bigger hammer" scenario.
Bob Young
COG #5753
