Author Topic: Emergency Throttle Cable Repair  (Read 330 times)
Offline Uncle Rob
  • "Knock it off with those negative waves!"
  • COG#: 11810
« on: October 12, 2015, 04:00:39 pm »
I broke my pull throttle cable on the way to Barber and had to do some 'neck tech rigging to make it there.  You can switch the push cable to the pull cable at the carbs and on the grip.  Leave it in it's original position as it goes through the switch housing and put the plastic elbow from the pull cable in the switch housing without cable in it.  You will have a country mile of slack, but it will get you to the end of the ride.
Thanks to Murph for next day airing me a new set.  It probably would have made it home, but it is a lot less stressful if you aren't worried about your bike breaking down.
2003 C10
1999 Buell X1
Others in pieces
Rob Thomson
Offline cra-z1000
  • Keeping it upright..
  • COG#: 9790
Re: Emergency Throttle Cable Repair
« Reply #1 on: October 12, 2015, 04:22:47 pm »
good tip ! :beerchug:
1987 C 10
80 Kawasaki KZ 1000 MK 2
74 Honda 750 four ss
73 Suzuki 550 triple
72 Honda 550 four
