Author Topic: engine swap  (Read 428 times)
Offline david
engine swap
« on: March 14, 2020, 12:56:30 pm »
ok guys I have 1 connie , runs amazing, had the carb kits, the tubes everything done runs like a new bike, but shes  not a looker spent a lot of time outdoors, bad paint, cracked plastics just a ugly duckling,   I have 1 connie   hydrolocked,  but looks almost new,   so the question is,    for dumbass with a handful of harbor freight tools, should I     put the good engine in the pretty bike or the good plastics on the ugly bike, what would make more sence,      and also running ugly bike 74000 miles    pretty non runner 24000 miles
Offline Stasch
  • COG#: 6830
Re: engine swap
« Reply #1 on: March 14, 2020, 02:02:58 pm »
All else being equal between your two bikes and having done carbs on/off and engine swaps before, there is a lot more work and expertise needed IMO to R&R engines than to just swap body and accessories between bikes, especially since you're going to have to pull a lot of the plastics from both bikes to change out the engine anyway.
Any farkle swapping that is needed will be relatively easy as most are bolt on and / or wiring in scenarios (nod to your 'harbor freight' comment!)
Sounds like a fun project.    >:D
Keep us posted.
Stan Visser - COG#: 6830
Offline batboy
  • COG#: 12983
Re: engine swap
« Reply #2 on: March 14, 2020, 05:39:16 pm »
What kind of damage did the hydrolock do? Often they can be repaired. If it bent a rod, you'll have to pull the motor out anyway.
But, if it don't have a bent rod, why not keep the ugly one to ride for right now and keep the pretty one to work on and repair at your leisure?
Offline crag antler
  • COG#: 8277
Re: engine swap
« Reply #3 on: March 14, 2020, 05:54:41 pm »
David, IMHO i would put the ugly motor in the hydro bike.
Just me.
Where are you located? Could be up for help if not too far from Western NC.
Thought I'd throw that out.
Doug aka crag antler
00’ C-10 w/ 60k +
Offline Stasch
  • COG#: 6830
Re: engine swap
« Reply #4 on: March 14, 2020, 09:56:19 pm »
Only if its rod 1 or 4.
Rods 2 and 3 can be done without pulling the motor or splitting the cases.
Offline david
Re: engine swap
« Reply #5 on: March 15, 2020, 10:31:54 am »
It’s number 2.   And it’s a good 8th of a inch maybe alittle more,      I’m in Talladega Alabama,   I’d really like to put the good motor into thelow miles bike,   I hope to ride some of the western NC mountain roads this spring
Offline david
Re: engine swap
« Reply #6 on: March 15, 2020, 08:21:53 pm »
Sorry cylinder number 1 I ment
Offline kkja13
  • Tyler, TX
Re: engine swap
« Reply #7 on: March 18, 2020, 05:26:59 pm »
Are both bikes currently titled and registered?  The VIN on the frame may become the deciding factor.
2004 C10
2003 Suzuki SV650s
Offline david
Re: engine swap
« Reply #8 on: March 19, 2020, 08:03:56 pm »
yes both are titled, and completely legal paper work wise
Offline kkja13
  • Tyler, TX
Re: engine swap
« Reply #9 on: March 23, 2020, 04:09:55 pm »
In that case I would make the good engine bike look good!  Then ride it!  :motonoises:
2004 C10
2003 Suzuki SV650s
Re: engine swap
« Reply #10 on: March 25, 2020, 06:24:43 pm »
e bay has some used Factory Service manuals. Be careful of the location. I would get one and read through the engine removal and see if this is something you want to tackle. I took the motor out of my Z1 900. I know it's not the same bike but it was pretty straight forward.
