Author Topic: Engine temperature issues  (Read 1531 times)
Offline Dave
Re: Engine temperature issues
« Reply #25 on: May 18, 2017, 06:36:51 pm »
 Once again, thanks for all the input about the temp gauge issue. Jim, the photo of your gauge at "Cold" is where mine lives about 99% of the time. It's snowing here today or I would get her out and warmed up for a pyrometer / temp check. Sounds like most likely an under performing sending unit. Will try SISF's suggestion about grounding, then try a resistor to get this unit working properly. Since the bike doesn't seem to really be running hot, I could also try some nice thick tape over the temp gauge. Was seriously considering getting a new FJR, but now I think I'll just see if I can wear her out instead. Thanks everyone !
Offline Jim
  • Jim
« Reply #26 on: May 18, 2017, 06:56:54 pm »
The sending unit is probably working just fine.  The gauge has the non-linearity problem.  When you momentarily short the wire on the sending unit to ground, the needle should go all the to the edge of the gauge.  Also, if you have a meter, measure the resistance from the nut on the sending unit to battery or frame ground (not the thermostat housing).  Should be < 1 ohm.
Offline alan
  • COG#: 11951
« Reply #27 on: May 18, 2017, 08:39:24 pm »
+1 on the tape idea.   :)
....ride like the one-eyed Jack of Diamonds with the Devil close behind...
-Robert M. Pirsig
« Reply #28 on: May 18, 2017, 10:17:36 pm »
Do you think, possibly, that using a teflon tape, or other sealant, might effect grounding?
Well, as the thermo housing is sitting on a tube, with an o ring seal, and the only metal to metal contact from that point, is the bolt that holds them together.. might want to revisit all that grounding path... :great: :beerchug:
Offline Jim
  • Jim
« Reply #29 on: May 19, 2017, 04:21:51 pm »
If you do remove the sending unit, absolutely goes easy on the tape.  2 wraps, tops.  Be sure to support the thermostat housing when tightening the sending unit back up.  Then check the sending unit nut to frame ground to make sure that sole bolt MOB mentioned is providing a good path.
« Last Edit: May 19, 2017, 04:26:33 pm by Jim »
