Author Topic: Fairing Washer Replacements in Stock Size  (Read 467 times)
Offline Voskomm
« on: November 16, 2018, 08:09:01 pm »
Hi All!
Does anyone have a good source for fairing washer replacements? These look to be black nylon M6x16mmx1.5mm. I can find standard M6 with a 12mm outside diameter easily but not 16mm.
Thanks for any help!
Re: Fairing Washer Replacements in Stock Size
« Reply #1 on: November 16, 2018, 10:17:25 pm »
  If you can't find them you can get an entire kit here .   Murphs' ships fast. :great:
    https://www.murphskits.com/index.php?cPath=1_95&osCsid=IxCtaaNF1T63RZ2TyRy3
« Reply #2 on: November 16, 2018, 10:35:12 pm »
Hi All!
Home Depot or Lowe's...
white or black nylon washers are cheap, so are rubber ones if you want those.. not a big deal.
buy ones for 1/4" screws, O.D. can be anywhere from 1/2" to 5/8", which work fine...
thickness is moot, it's just to protect the plastic.
Offline Voskomm
« Reply #3 on: November 16, 2018, 11:08:04 pm »
I should say I *have* a stack of standard M6x12x1.5 currently but they leave an unsightly and water retaining gap between the edge of the stock screw and fairing. Call me a perfectionist but I'd like to match the ones that haven't run off on this bike. I've checked HD and Lowes but they only seem to have standard metric washers.
Offline Voskomm
« Reply #4 on: November 17, 2018, 12:03:34 am »
Ah-ha! M6x18x1.5 seems to be the common wider M6 washer size. Found em, thanks!
« Reply #5 on: November 17, 2018, 12:16:18 am »
Lowe's and Home Depot, and True Value/Ace hardwares stores have way more SAE (non metric) hardware than metric... here in the USA....
and a 6mm screw is just slightly smaller than a 1/4" (by .014")... I don't see why it would be hard to choose...
or, buy the Kaw parts....
WASHER,6X16X1
92022-1818
$1.30  EACH....
you won't find the nylon ones with the o/d you are asking for, anywhere's else... it's not the common size associated with a generic fastener, sorry...
Just buy these, they will grip the screw, and not get lost, and will seal, as you seem to be very.....fixated... on that, which is not what they were ever intended for in the firstplace..
anyways, they ship like overnight...$11.17 per pack of 100... but they are superior, as they are Rubber.... and stick with the screws...
https://www.mcmaster.com/90133a032
good luck.
« Last Edit: November 17, 2018, 12:22:07 am by MAN OF BLUES »
Offline Voskomm
« Reply #6 on: November 17, 2018, 12:44:42 am »
I ordered a stack of the 18mm. I will try to carry on with my life, knowing there is 1mm more nylon around my screws than Kawasaki has deemed necessary.  >:(
That mcmaster carr site is great though, I'm going to have to remember that; I'm sure something else will come up.
Offline LeeM
  • COG#: 12454
« Reply #7 on: December 02, 2018, 03:35:18 am »
I make my own fairing washers from hardware store sheet neoprene. The hardware store has 1/8" and 1/16" sheet neoprene.
I have a small punch set (from China) with a 1/4" hole size for 6 mm screws. I used to cut the washers freehand with sidecutters or tin snips. I have another punch set with a 3/4" hole size. In a few cases, i use slightly longer 6mmx17mm stainless steel pan head screws with a 6mm sstl fender washer. Mark the neoprene with ball point pen before punching.  With a hammer and a hardwood block, I can make 4 washers at a time. Good idea -- put on hearing protectors when using the punches.
Offline bajasam
« Reply #8 on: December 02, 2018, 02:50:09 pm »
What ! There's supposed to be washers on my fairing fastners ??
« Reply #9 on: December 02, 2018, 09:12:11 pm »
I mentioned this a couple months ago, I do the same thing, make them from Laundry detergent, windshield washer, antifreeze, bottles... even old Oil bottles... you can find a suitable color, and make your own with a $7 punch set from H/F...
I just chuck the punchs (small hole first, then big to pop out the washer) in my Drill press chuck, lay a piece of wood on the platten, insert strip-o-plastic, and use the press as a manual press... ez-pz... no pounding or hearing protection needed.. I don't even use safety glasses...
 :)) :)) :rotflmao: :rotflmao: :rotflmao: :great: :great:
