Author Topic: Front Brake Conversion  (Read 3108 times)
Offline Jim Snyder
  • COG#: 7055
Re: Front Brake Conversion
« Reply #25 on: June 26, 2018, 01:23:54 am »
I think these are the ones I used.
Offline Jim Snyder
  • COG#: 7055
Offline Jim Snyder
  • COG#: 7055
« Reply #27 on: June 26, 2018, 02:50:12 am »
I'm running radial calipers and 310mmm rotors on my 2006 C10. REAL brakes on the front now. Brackets came from a Chinese machine shop, imagine that.
The challenge was getting the speedo cable routed properly. Ended up using a cable extension and relocating the 'pin' on the speedo drive.
I ordered a custom extended speedo cable. It had enough of slack to make the bend with no problem.
