Author Topic: Fuel Line  (Read 273 times)
Offline croach1776
  • "You cant lose what you never had," - Fatty Roach
  • COG#: 9094
Fuel Line
« on: June 29, 2020, 03:27:49 pm »
During derusting tank have decided to install the Wix 3006 fuel filter and also to install new fuel line. Any suggestions on how to
remove old fuel line from carbs. Where it enters is a very restricted space so any hacks to make it easier would be greatly appreciated. Thanks
C K Roach Jr  IBA#42837  SS-K  COG#9094  CDA# 0319  AMA# 2704431 _ "you cant lose what you never had"  2005 Concour "Gold Rush"  - Suzuki C50 Boulevard - 1983 Suzuki GS750ES - Sold  1982 Suzuki GS650G - Sold
Re: Fuel Line
« Reply #1 on: June 29, 2020, 06:44:22 pm »
stick a piece of wire coat hanger, or a long thin screwdriver thru the hose, position it on the fitting, and jamb the hose into place
Offline Bob_C_CT
Re: Fuel Line
« Reply #2 on: June 29, 2020, 08:33:58 pm »
I use longggg needle nose pliers to remove. If I remember correctly the inlet tube on the carbs is plastic so I would not use a razor in the needle nose plier to slit the tubing to help remove. MOB has the good idea on install.
Southern Connecticut.
Offline RWulf
  • COG#: 7122
Re: Fuel Line
« Reply #3 on: June 29, 2020, 09:01:26 pm »
Also I spray some WD 40 on the plastic nipple. Makes it slip on easier.
Re: Fuel Line
« Reply #4 on: June 29, 2020, 09:54:33 pm »
makes them slip off, just as easy also... doh.
go to the Kaw store, and get clamps for the fuel line... 92037-1075... a couple bucks, OEM, and never changed over 50 years of bikes... slip them on the hose, jamb them in place.. and ride.
« Last Edit: June 29, 2020, 10:06:03 pm by MAN OF BLUES »
Online m in sc
    • 2strokeworld.net
  • COG#: 13057
Re: Fuel Line
« Reply #5 on: June 30, 2020, 01:58:53 am »
i use small zip ties pretty regular to hold on gravity feed fuel lines, never an issue. (just an option). I wouldn't use wd either.
Re: Fuel Line
« Reply #6 on: June 30, 2020, 07:55:05 pm »
 :great: :great:
I have a specific "zip tie" installer tool, it clamps on the tie end, and wratchets it tight as can be, and snips the end.. priceless tool I acquired working in the electronics industry I was engineering for over many years.. and man, it will "zip" and tighten a tie amazingly tight..
Online m in sc
    • 2strokeworld.net
  • COG#: 13057
Re: Fuel Line
« Reply #7 on: June 30, 2020, 08:20:51 pm »
those are great. the ratcheting one with the trigger?  :great:
Offline croach1776
  • COG#: 9094
Re: Fuel Line
« Reply #8 on: June 30, 2020, 10:41:52 pm »
Thanks all good ideas
Offline cra-z1000
  • Keeping it upright..
  • COG#: 9790
Re: Fuel Line
« Reply #9 on: June 30, 2020, 10:48:16 pm »
I believe your original question was removing the fuel line from the carbs . I can usually work a long screwdriver in there and pry it off the fitting . I put mine on while the carbs are out and position the clamp where I can get to it if needed .
1987 C 10
80 Kawasaki KZ 1000 MK 2
74 Honda 750 four ss
73 Suzuki 550 triple
72 Honda 550 four
Offline croach1776
  • COG#: 9094
Re: Fuel Line
« Reply #10 on: July 01, 2020, 05:40:56 pm »
Ya. I decided against doing that at present as carbs have recently been cleaned.  As of now I am having an electrical issue that I have finally traced to a red/white wire coming off bottom of Jbox. the inline connector has corroded and will need to be replaced. So I see this as a blessing of avoiding Murphys law. Better to find issue in garage vice on the road.
Offline TireguyfromMA
  • COG#: 12669
Re: Fuel Line
« Reply #11 on: July 01, 2020, 08:05:32 pm »
This tool   https://www.motionpro.com/product/08-0646  from Motion Pro might be exactly what you need.  I use it all the time to remove rubber coolant and fuel hoses on the bikes and cars .
2002 Honda ST1100
Re: Fuel Line
« Reply #12 on: July 01, 2020, 08:07:40 pm »
YEP... The big $$ model, from Panduit... commercial grade.. we would replace them all in our shop every 3 or 4 years, and they would toss the older ones.. I grabbed one up outta the garbage bin.... :rotflmao: :rotflmao: :great:
Re: Fuel Line
« Reply #13 on: July 02, 2020, 09:28:15 am »
Yeah they used those in the induction and shaded pole finishing departments when I worked there back in the day.  Is that something that can be bought from McMaster?
2013 Kawasaki Concours 14
