Author Topic: Fuel tak not venting properly  (Read 400 times)
Offline Mike
« on: November 07, 2018, 10:10:23 pm »
2002 Concours starves and dies after sitting an hour or so. The problem goes away after opening the fuel tank. I'm pretty sure the fuel cooled and created a vacuum. Mr. know it all, read on the forum about a couple diaphragm check valves down in the bowels of the gas cap and I went looking for 'em. They're bad, do I need 'em, where can I get 'em? It looks like Kawasaki doesn't sell the orange rubber diaphragm valves.
Re: Fuel tak not venting properly
« Reply #1 on: November 07, 2018, 11:43:12 pm »
what do you consider "bad"?
 just curious.
Offline Mike
« Reply #2 on: November 08, 2018, 04:57:22 am »
Tips that held them in just fell off, the rest of the valve was ok. Any suggestions will be appreciated.
« Reply #3 on: November 09, 2018, 07:04:54 pm »
I don't think you will find 'replacement' flaps.
maybe in a cap from e-bay, but then that could be an old funkey cap to begin with.
when most folks pull these apart to 'fix' the venting / whistle issue, they simply leave them out... I don't do that, as I think it creates moisture issues in the tank downstream after time.
sorry, can't help much other than that.. :truce:
Offline Mike
« Reply #4 on: November 09, 2018, 08:18:45 pm »
I don't want to leave them out as you said "I think it creates moisture issues in the tank downstream after time". It's fixable if the parts are available. I guess Kawasaki just doesn't feel it's necessary to handle such a cheap part for an obsolete bike.
Mike
« Reply #5 on: November 09, 2018, 11:08:45 pm »
Mike
   Have you looked here. Don't know if this helps.?
    https://www.ebay.com/itm/Fuel-Gas-Cap-Tank-Cover-Lock-2x-Keys-For-Kawasaki-ZX-6R-7R-9R-ZG1000-Concours/323327162570?hash=item4b47ccf8ca:rk:4:pf:0
« Reply #6 on: November 10, 2018, 12:07:26 am »
$20.... man new part, jump on that one right now..... don't hesitate, I'll be buying them all... :))
Offline Mike
« Reply #7 on: November 10, 2018, 05:48:32 pm »
[/quote]
Says "This part is not compatible with 2002 Kawasaki Concours 1000 ZG1000A" probably because of the finish (silver) on the ring. For $20 I gotta give it a try.
« Reply #8 on: November 10, 2018, 08:38:26 pm »
physically, the tank and lid assembly for all Concours from '86 thru '06 is identical...
go for it.... :great: :great: :great:
