Author Topic: header nuts  (Read 679 times)
Offline EZ
  • COG#: 11785
header nuts
« on: July 31, 2018, 01:11:15 pm »
Does anyone have a source for the 8mm fugi header nuts? Amazon is out - Fastenal, Grainger .... no joy.  Found one source but I really don't want to spend $48.00
Offline turbo-max
  • COG#: 10445
Re: header nuts
« Reply #1 on: July 31, 2018, 01:57:15 pm »
how many do you need? im sure i have a few used...sending a PM also
99 c-10 "the purple monster"
Offline EZ
  • COG#: 11785
Re: header nuts
« Reply #2 on: July 31, 2018, 02:36:03 pm »
Thanks TM. Just realized this was in ZG 1000 not 1400, where it should be. If its not moved in a day or so I'll re post there..
Re: header nuts
« Reply #3 on: July 31, 2018, 06:54:38 pm »
I figured that, I'll note a mod to move it, so check there later...
in the meantime, these are what work, and cheaper...
Exhaust Header Nuts (Replacements) -
McMaster-Carr 93795A230 M8.0 Oval Lock nut.  Use with stainless steel washers.
(Note:  The 2010 Service Manual shows the required torque @ 13ft/lbs.)
My personal opinion tho, working and specifying fasteners and torques and such, is that trying to achieve a 'torque' rating on a 'deformed' style lock nut, is nullified by the force it takes to simply tighten it on the threads, so I suggest just prudent 'good-n-tite' without bending the flanges.
best of luck, :great:
« Last Edit: July 31, 2018, 06:58:11 pm by MAN OF BLUES »
Offline EZ
  • COG#: 11785
Re: header nuts
« Reply #4 on: July 31, 2018, 09:32:55 pm »
I love it! I knew you'd come through if I posted it here  :truce:
Cheaper and works well, say no more. That's a done deal and as always this cat appreciates your input Rich!  :beerchug:
Re: header nuts
« Reply #5 on: July 31, 2018, 11:50:37 pm »
I have not used the nut I noted, on the header studs, so I caution about their usage, being as they are a higher strength rated nut... just be careful and don't strip the studs...
In applications where lock nuts are removed maybe twice in the life of the machine, I don't worry; but in cases where more removals are required periodically, I worry they may at some point, damage the threads as they do squeeze the threads during the deformation process on the nut.
My personal opinion is to use a 'Keps' style (captive star washer), which are quite good at resisting the nut from backing off, without possibility of thread damage...
https://www.mcmaster.com/#metric-nuts/=1dyj1l1
or even 'serrated flange' nuts, which allow use without the need of a flat washer under them...
https://www.mcmaster.com/#metric-nuts/=1dyj5fo
both types in my book, work well, and are common industry standard for things like this.
and, comparably priced.
