Author Topic: Headlight wiring  (Read 1998 times)
Offline Tjnoma99
  • COG#: 12686
Headlight wiring
« on: August 30, 2017, 01:41:18 am »
So the previous owner wired in a hid headlight. I'm nut a fan. So I pulled the fairing and the headlight writing has been chopped up. My question is which wire is which? I have an electrical diagram but come to find out, I'm not too good at reading them ( I'm a plumber by trade)! And I noticed that there is no headlight connector. The bike takes an h4 correct?  Thank in advance!
Offline Jorge
  • COG#: 9297
Re: Headlight wiring
« Reply #1 on: August 30, 2017, 01:52:25 am »
Yikes!!
Hey, plumbing and wiring are the same, just don't mix them.
Yes, they take the H4 bulb.
I think you can get a replacement connector at any auto parts store. The plug is the same as the old hi/lo sealed beam light that millions of cars and trucks used, and many still use the same plug.
I'm sorry I can't remember which connector is which wire; possibly the replacement connector will have a guide.
From looking at the wiring diagram, the red/black wire is the high beam, the red/yellow is low, and the yellow/black is ground.
I recommend that you solder the connection, even if you use a barrel crimp connector, use a bare one, and put heat shrink tubing over the connection. There's quite a bit of current flowing through these wires, and you don't want to overheat them.
The solder in the joint prevents corrosion between the wires, and the heat shrink tubing will protecxt the connection, and isolate it preventing a short circuit.
Offline Tjnoma99
  • COG#: 12686
« Reply #2 on: August 30, 2017, 01:55:49 am »
I don't know about being the same! Never been shocked by water ;)
That it's all the info I was looking for! When I pulled the hid harness off, all the connections went with it. So I will be soldering everything and using shrink tube!  Thanks for the info!
Offline JimBob
  • Woman...WHOAAAA MAN!
« Reply #3 on: August 30, 2017, 03:43:05 am »
May save you some headache to get Murphs headlight wiring upgrade kit.
https://www.murphskits.com/product_info.php?cPath=1_92&products_id=102[/font]
Offline Jim
  • Jim
« Reply #4 on: August 30, 2017, 10:47:47 am »
And here's one from NAPA ...
Offline Tjnoma99
  • COG#: 12686
« Reply #5 on: August 30, 2017, 01:03:47 pm »
I was thinking of doing this. Is it worth it?
Offline Derick
    • BeginnerBikers.org
« Reply #6 on: August 30, 2017, 01:57:04 pm »
Wired in?? It shouldn't have really been anything different than a drop in. Most HID's are plug and play...there is just more to it. Ballast and lots of extra wiring. Some HID kits do use a relay, and so there is the HOT wire that goes to the battery that may be what is 'wired in' but shouldnt be much more than that.
When it's all said and done, a lot of people use LED drop in bulbs from amazon. I did, and I like it just fine. It is a small pigtail and a small ballast to keep voltage steady but it will cut down on excess wiring. I removed my HID kit for the same reason...too much extra 'junk' tucked into the fairing. I like a clean, easy to service setup.
Current Bikes:
Offline Tjnoma99
  • COG#: 12686
« Reply #7 on: August 30, 2017, 03:30:44 pm »
What I'm assuming us the previous owner bought a universal kit, not bulb specific. He cut out the stock connector and hard wired the setup in. When I went to pull out the bulb, the new connectors all pulled off. I have a led bulb I want to use but I would prefer to have the stock connector. So now I need to solder on connectors or the stock one.
Offline JimBob
« Reply #8 on: August 30, 2017, 04:52:02 pm »
When you say the wires came out with the bulb, the wires for an HID bulb are NOT the same wires for a conventional/incandescent/factory bulb. The wires on the HID come from the ballast.
HID is like fluorescent - it uses high voltage to drive an arc inside the gas in the bulb. To do this, the 12v system is connected to a ballast which steps-up the voltage.
Are you SURE the factory wires are modified? Every kit I've used (10 or so in the last 12 years) uses a standard light connector to attach to the factory wiring (plugs into the bulb connector), which then goes to the ballast, and wiring from the ballast goes to the HID bulb.
Offline Tjnoma99
  • COG#: 12686
« Reply #9 on: August 30, 2017, 04:54:07 pm »
I will double check. I just know everything kinda fell apart when I pulled the bulb. Hopefully I just looked at it wrong.
Offline Derick
« Reply #10 on: August 30, 2017, 04:56:32 pm »
Oh my...that PO was an idiot. That's waaaayyy more work than buying a drop in. Some people.... sheesh  :-[
Current Bikes:
Offline Redbarron
  • COG#: 10045
« Reply #11 on: August 30, 2017, 05:09:16 pm »
I strongly recommend the Murph's Kits dual relay kit.
Their are plenty of YouTube videos that should help you with wiring, soldering and heatshrink Technics.
Offline Outback Jon
  • COG#: 9506
« Reply #12 on: August 30, 2017, 06:37:06 pm »
If he's going to LED, I don't think the Murph's relay kit will be any advantage.  LEDs seem to work just fine, even with a lower than optimum voltage.
I put a set in my car, and the ~6v for the DRLs lit the LED unit at full brightness.  Had to figure out how to disable the DRL circuit.
Offline Tjnoma99
  • COG#: 12686
« Reply #13 on: August 30, 2017, 07:09:28 pm »
You have no idea! I'm finding random wires and relays that aren't connected to anything! I have what I think is a separate accessories fuse panel but I can't get it open to figure it out! The little screws that hold the lid on were once Phillips heads. I've done my best to trace each wire physically and with the diagram, and it's been interesting! But I'll get it sorted out sooner than later!
Offline Jorge
  • COG#: 9297
« Reply #14 on: August 30, 2017, 10:30:23 pm »
The wire colors I typed in were from my Clymers manual; maybe someone else can verify them or you can by using a voltmeter, and confirming you have voltage between hi & ground and lo & ground depending on your dimmer position.
I agree with the comments about LEDs from Amazon. I bought teh Eviteks, and they are amazing, and draw less current then the stock H4 bulbs. Murph's kit would be a waste with LEDs, due to the lower current used, and the fact that the LEDs come with electronics to regulate the voltage to the right level needed by the LED chips.
Jorge
Offline Tjnoma99
  • COG#: 12686
« Reply #15 on: August 31, 2017, 12:04:07 am »
So I got a chance to look a little deeper, and yes, the previous owner cut off the oem headlight connector. No biggie, I have the technology, it can be fixed! AND I did find an fuse panel for my accessories. It's on a relay and everything! Can't wait to be able to take this monster out and ride!
Offline Derick
« Reply #16 on: August 31, 2017, 12:18:26 am »
Re-usable parts are still usable parts! I took off a relay and fuse block system off my goldwing (that I installed) to replace with a Rowe PDM60. That sucker is the bentley of fuse blocks. Was able to turn around and put that stuff in the project connie.
Just make sure you do a better  job of wiring than this other clown did.
Current Bikes:
Offline Tjnoma99
  • COG#: 12686
« Reply #17 on: August 31, 2017, 12:21:53 am »
Oh I plan on it. Already got the soldering gun out. I've got plenty of time this weekend to rewire some things. Plus I can get a charger or two connected!
