Author Topic: Hot Foot  (Read 596 times)
Offline Warwgn
Hot Foot
« on: May 22, 2019, 08:13:45 pm »
Anybody else get a lot of heat on the right ankle?
This was never a problem in the past but it has been getting worse, thinking maybe an exhaust leak or something maybe, and has slowly started to show up on the left side now. I have been riding this bike for two years and this has never been an issue before so kinda stumped?
Re: Hot Foot
« Reply #1 on: May 22, 2019, 08:25:23 pm »
Did you happen to remove the piece that blocks air flow above the radiator.
I did and discovered it allowed more hot air flow at my ankles.
« Last Edit: May 22, 2019, 08:36:03 pm by connie_rider »
Re: Hot Foot
« Reply #2 on: May 22, 2019, 08:31:15 pm »
Ride safe, ted
Or maybe it just came loose from it's proper position.
2013 Kawasaki Concours 14
Offline Warwgn
Re: Hot Foot
« Reply #3 on: May 22, 2019, 08:48:25 pm »
I will check that, not to mention I hit a dog recently so I am sure it is all f'd up anyway along with the lower cowl, but it was getting hot foot before that happened.
Maybe I should just take all the lower cowling off since they are broken anyway and held on with Duct Tape now :great: But I am still riding!!!
Offline Stasch
  • COG#: 6830
Re: Hot Foot
« Reply #4 on: May 22, 2019, 10:36:01 pm »
Stan Visser - COG#: 6830
Re: Hot Foot
« Reply #5 on: May 22, 2019, 11:29:49 pm »
Since you mentioned the lower cowling being broken, then your lower heat shields might be broken, allowing them to shift and not seal properly.
Offline m in sc
    • 2strokeworld.net
  • COG#: 13057
Re: Hot Foot
« Reply #6 on: May 23, 2019, 04:11:36 pm »
def check all shields. when i was learning that my upper one wouldn't stay (until i made the bracket to fix it), when it would 'fall', it would heat up one side or the other notably , depending where it let loose.
Offline Warwgn
Re: Hot Foot
« Reply #7 on: May 30, 2019, 02:00:32 pm »
do you need to pull the tank to do the upper shield, I cant seem to see how it is supposed to be?
Re: Hot Foot
« Reply #8 on: May 30, 2019, 02:34:00 pm »
I would think it would be a bear to do if you didn't pull the tank.  Pulling the tank is easy unless you have a full tank of fuel.
Offline m in sc
    • 2strokeworld.net
  • COG#: 13057
Re: Hot Foot
« Reply #9 on: May 30, 2019, 03:00:16 pm »
yes, pull the tank.
