Author Topic: How to change fuel supply hose?  (Read 463 times)
Offline Bucky
  • COG#: 11949
« on: October 23, 2017, 04:13:12 pm »
It appears that the bottom of the fuel supply hose, where it connects to that area between the carbs, it's a little difficult to install. Any tips or tricks to help me install a new fuel supply hose?
Thank you.
Antique Machinery Junkie
Offline Jim
  • Jim
Re: How to change fuel supply hose?
« Reply #1 on: October 23, 2017, 04:20:30 pm »
Thread the fuel hose on a long Phillips screw driver then carefully put the driver head into the nipple at the carbs.  Lube the end of the hose with a little fuel or armor all to ease insertion.
Offline Bucky
  • COG#: 11949
« Reply #2 on: October 23, 2017, 04:39:14 pm »
Wow. What a good idea. You da man.
I thought for sure I would have to go to the cuss-words store and stock up.
 Thank you  :great: I
I don't think I have a Philips that long, but I'm right next to a hardware store and I would reckon a wood dowel will do the same thing. Maybe I'll sand a little point onto the end of the dowel.
« Last Edit: October 23, 2017, 04:44:57 pm by Bucky, Reason: Because I am old and feeble minded »
Offline who me?
  • COG#: 11932
« Reply #3 on: October 23, 2017, 04:53:00 pm »
I bought out the cuss words store the other day
95 C10 The Mule
02 C10 parts are parts
Offline Jim
  • Jim
« Reply #4 on: October 23, 2017, 05:06:53 pm »
I read about that trick somewhere else on this forum and it has saved me an untold amount of frustration on several occasion.  You can get a 22" long screw driver set from Harbor Freight for $5.  Great for syncing carbs, too.
Offline Bucky
  • COG#: 11949
« Reply #5 on: October 23, 2017, 07:20:33 pm »
New fuel line installed, big smiley mug on me.
That will be two issues removed from my fuel starvation campaign -- the auxiliary fuel filter, and the 14 year old fuel line.
Today it's 30 miles to home. Time will tell. I have a feeling the new hose is not going to help, but we'll see. Kind of wondering if it's that little vacuum deal that opens petcock. Petcock parts on the way from Ron Ayers. Thanks to a tip from Man of Blues.  :great:
« Reply #6 on: October 23, 2017, 07:48:06 pm »
While you're replacing lines, replace the vacuum line that goes to the petcock.
