Author Topic: How to stop hazard lights stuck flashing on 2003 concours?  (Read 105 times)
Offline purepoetry
« on: September 01, 2019, 07:57:08 pm »
How do I stop the hazard lights from continuously flashing on?
I've punched the little red button a number of times on my 2003 concours
Offline bajasam
Re: How to stop hazard lights stuck flashing on 2003 concours?
« Reply #1 on: September 01, 2019, 09:24:03 pm »
best start would probably be to pull it off the handle bar take it apart for a good cleaning.
Offline LeeM
  • COG#: 12454
« Reply #2 on: September 02, 2019, 01:40:43 am »
Try some squirts of WD-40, at least before you begin a disassembly. I recently took apart the clutch squeezed starter allow switch on the same right handlebar. The switch was nicely done but the parts are dinky. Cleaning and re-assembly without losing the spring in outer space resulted in a working switch.
Suggestion 1 is to lay down rags to prevent parts from dropping into the bike. Suggestion 2 is to be ready for a latch with a spring to pop out when you have it apart. Suggestion 3 is to disconnect the battery ground cable before starting work.
So tell us, was the failure due to salt, grease or somebody we shall not name?
Offline cra-z1000
  • Keeping it upright..
  • COG#: 9790
« Reply #3 on: September 02, 2019, 04:53:54 am »
This happened to mine once . Try pushing on the button and moving it up and down while pressing in . I have never used the hazards again .
1987 C 10
80 Kawasaki KZ 1000 MK 2
74 Honda 750 four ss
73 Suzuki 550 triple
72 Honda 550 four
